Need Fender Help
Old Mar 15, 2008 | 08:36 AM
Prowler217's Avatar
Prowler217
Default Need Fender Help
Hey i need to know how do you PULL a fender about a half inch to and inch without taking the car to a shop? its in pieces rightnow and i dont want to put it back together to move it to re put it together. PLEASE HELP>.
curtis
Old Mar 15, 2008 | 08:57 AM
Lex-Fiend's Avatar
Lex-Fiend
If the only issue with taking it to the shop is putting it back together, I would just tow it, especially if you've never done it. IMO
Old Mar 15, 2008 | 10:26 AM
turbodremz's Avatar
turbodremz
post pics...that would help
Old Mar 15, 2008 | 11:00 AM
Prowler217's Avatar
Prowler217
45/prowler2177/lex1.jpg[/IMG]
here are a few shots.
Old Mar 15, 2008 | 12:28 PM
Black_SC's Avatar
Black_SC
just lower it some more and you wont need to pull fenders.......
Old Mar 15, 2008 | 12:43 PM
Lex-Fiend's Avatar
Lex-Fiend
+1^^ If you lower it, you will have more neg camber so it will look really good, you might have to roll your fender only.
Old Mar 15, 2008 | 02:29 PM
shern's Avatar
shern
Are you rubbing on the fender or the bulge in the wheel well?
Old Mar 16, 2008 | 01:46 AM
Prowler217's Avatar
Prowler217
yeah i am running 265/35/18 in rear with little problem but i have a new set of 275/35/18 that i csant put on cause they just barely fit. was told to have the inside rim shaved down to pull rim under more. is that able to be done?
Old Mar 16, 2008 | 07:51 AM
RikTT's Avatar
RikTT
so youre rubbing with the 265 and now you are going to put 275's? lil confuse
Did you try lowering on the 265's to see if the neg camber helps? Im guessing youre outter tire is rubbing. I cut/shaved my fenders to run 285's btw
Ricky
Old Mar 16, 2008 | 09:31 AM
bigmalik00's Avatar
bigmalik00
yep lower it and use a bat if it rubs...
Old Mar 16, 2008 | 09:50 AM
SC4_FI's Avatar
SC4_FI
truck+towchain+fender
Old Mar 16, 2008 | 10:20 AM
BLovesc's Avatar
BLovesc
That is probably the worse thing you can do. Sunken wheels are fail. Plus that could factor in the integrity of the wheel. And also there is really no need to go with a bigger tire. Roll your fenders first actually. You could probably just hammer in that little lip that sticks out. Lowering the car in hopes that it will give you the negative camber that you need is not the proper correction for rubbing. Im sure if you did lower it it would still rub if not worse. So I would say hammer in that lip if it still rubs then go get your fenders rolled
Old Mar 16, 2008 | 06:44 PM
Prowler217's Avatar
Prowler217
thanks guys. well my fenders were rolled and shaved by a hop. they still rub a little, i want to out the 275 on but i know they will rub for sure. i just want to pop the fender out a little so its all flush or shout i have the rims shaved to a different offset.they are +22 now.
Sanddwich
Jul 3, 2014 03:29 PM
Mr_LS460
Jun 26, 2012 01:51 PM
Silver'04
Apr 4, 2011 10:09 AM
entryspeed
Florida Lexus Club
Feb 23, 2011 05:21 PM
SNiiP3R
Mar 1, 2010 04:44 PM
