Brakes
Old Mar 9, 2008 | 08:42 PM
Yahoo27's Avatar
Yahoo27
Default Brakes
I changed my brakes, rotors and brake calipers everything works fine except when i step on the brakes, my cousin says the whole caliper moves a little bit when the brakes bite. All the bolts are tighten, is it because maybe one of the bushings that the caliper assembly sits on is bad?
Old Mar 10, 2008 | 07:07 AM
vipsoarer's Avatar
vipsoarer
the caliper shouldnt be sitting on any bushings. it is connected by a slide pin that allows the caliper to move back and forth (in and out if looking at the wheel) to clamp on the rotor. Is it making any odd noises? If it is just sliding towards and away from you when looking at the wheel from the side, then it is normal. Thats just how a sliding caliper works. now if you had a fixed caliper like the ls400's or supra tt's then youd have a problem.
Old Mar 10, 2008 | 08:41 AM
Yahoo27's Avatar
Yahoo27
It would move up and down a very little bit when i'm braking hard, but brakes works perfect and no noises are present
Old Mar 11, 2008 | 07:35 AM
vipsoarer's Avatar
vipsoarer
i would just double check the torque specs of everything from the bracket to the slide pins, if they check out you should be ok. You will get some deflection but it shouldnt be enough to see it without being right next to it the whole time.
Old Mar 11, 2008 | 07:51 PM
5sp_jzz30's Avatar
5sp_jzz30
you have a problem sir. the caliper should not "move" when it bites the rotor. not enough to actually see with the naked eye. make sure everything is tightened.
Alant514
Jan 11, 2014 12:07 PM
ISAVY
Maintenance
Nov 9, 2010 05:16 PM
witmaRX
RX - 1st Gen (1999-2003)
Sep 27, 2006 09:26 AM
rominl
Suspension and Brakes
16
Jul 28, 2006 12:45 PM
lex_ga
Mar 2, 2003 07:58 PM
