ODO acting weird.... it goes back!!!
Old Feb 21, 2008 | 04:58 PM
kpsouljah's Avatar
kpsouljah
Default ODO acting weird.... it goes back!!!
whats up CL!
i have a 92 lexus sc300 and its an auto.
anyway i bought this car last week from the dealer and it had only 91628k miles on it and i realize that ODO goes back to the 91627 when it hits the 91630.....
my RPM dont works and my speedo works sometime its goes on and off
and i heard thats most common problem on sc300/400.
right now im starting to freaking out because odo is going back to 91627....
i have no idea whats the true mileage in this car and wut the hell dealer did to this car n stuff.....
any suggestions???
Old Feb 21, 2008 | 05:10 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
there's no real chance that car is actual mileage. Might want to try contacting the previous owner by vin lookup at the DMV before it is too late. You might have a case against the dealer for odo descrepency.
Old Feb 21, 2008 | 05:31 PM
neurocity's Avatar
neurocity
Not quite my tempo
Where did you hear that?
Check to see if that gauge pod has been pulled...look underneath the top part of the gauge pod...Two covered mount holes...make sure they are not all scratched up from being pried open.
Old Feb 21, 2008 | 06:11 PM
kpsouljah's Avatar
kpsouljah
i heard that from this one website i forgot the name of the site....
Old Feb 21, 2008 | 08:30 PM
TRD_Power's Avatar
TRD_Power
Like O.L.T. said, you might want to contact the previous owner and run the VIN before it's too late. That is not a common problem at all on the SC300/400s. Good luck, man
Old Feb 21, 2008 | 09:17 PM
SC4_FI's Avatar
SC4_FI
i think he ment the needles/ gauges not the odo failing.
Old Feb 21, 2008 | 11:25 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
If his odo is wigging, I think he meant what he said
Old Feb 22, 2008 | 05:38 AM
kpsouljah's Avatar
kpsouljah
yes i ment the needles/gauges are common problems for sc300/400 not the ODO
my ODO is just messed up and im going to call the dealer where i got the car from....
Last edited by neurocity; Feb 22, 2008 at 04:20 PM. Reason: if I cant swear, no one can
Old Feb 22, 2008 | 12:33 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
I was actually referring to you saying it stops working, which is different from stopping lighting.
Old Feb 22, 2008 | 03:34 PM
mr2tosc4's Avatar
mr2tosc4
look at the brighter side, you'll have an sc that'll never break 100k!
Old Feb 22, 2008 | 03:49 PM
kpsouljah's Avatar
kpsouljah
lol thats true!!! man im going to take it to lexus and see what's the problem...
i know it aint gonna be cheap but o well...
i was thinking buy a used cluster and put it on but i dont know if thats going to be work or not so damn
Old Feb 22, 2008 | 04:05 PM
SC4_FI's Avatar
SC4_FI
well, when i said what i said, i was refering to the guy right above me, guess i should have quoted him, but he got what i was saying
Old Feb 22, 2008 | 04:19 PM
Kohinoor's Avatar
Kohinoor
i suggest you return the car back to the dealer from which you bought it. who knows what other problems youre gonna have.. this is just the tip of the iceberg.
Old Feb 27, 2008 | 09:57 PM
S14eva1's Avatar
S14eva1
I have the same problem....but my overdrive light also flashes off and on for no reason.
I think this problem is due to an incomplete circuit = bad ground
it seems like the gauges work fine,is just that power comes and goes....give inaccurate readings.
Im gonna trouble shoot this problem soon....if all else fails,Im just gonna get my hands on a 97+ cluster
Old Feb 28, 2008 | 12:17 AM
redhanded7's Avatar
redhanded7
i had almost the exact same problem. the problem for me was a loose ground. if you take off the center console, there should be a bunch of wires that are all grounded together. make sure they are properly grounded and secured. i think whoever installed the cd player in my car, forgot to tighten down the ground.
hope this helps!
flash9
Apr 28, 2015 01:39 PM
hunt718
Feb 19, 2015 04:47 PM
Bix49
Jul 10, 2013 03:51 PM
TJMay
Aug 10, 2011 02:23 PM
indypwr
Apr 12, 2004 07:00 PM
