Info needed, LSD Guts swapping.
Old Feb 7, 2008 | 09:46 AM
Biggu's Avatar
Biggu
Default Info needed, LSD Guts swapping.
Hello all, Ive done some searching on this for the last few days but not much seems to be listed for it. What im going to be doing is a LSD install on my 92 sc300. i already ordered a Kaaz 2way LSD from a shop and that should be here soon. every thread i have found people just replace the carrier housing, im replacing the guts however. i saw that i need 10mm hex and the 12mm hex to drop the diff out. thanks to blizzy i found out the backlash is 0.08-0.13mm or 0.0031-0.0051in. ok well heres the real info i need, i found out the bearings that are needed for the diff are 90366-50033, called toyota and they confirmed that they are on the supras, called lexus and they confirmed they are on the sc300s. what i was wondering is should i also get the seals? snap rings? anything else or do i have it covered. when i did my LSD in my old miata i never replaced the snap ring nor the seals but every car is different. any help is greatly appreciated on it. i will also probably make a how to for others on this.
Old Feb 7, 2008 | 09:52 AM
Biggu's Avatar
Biggu
of course once i post this i find the thread with everything i need in it
https://www.clublexus.com/forums/sho...t=side+bearing
mods feel free to delete this
DOH!!
Old Feb 7, 2008 | 07:26 PM
Blizzy's Avatar
Blizzy
This post has service manual photos showing every part unable to be reused with a diamond. https://www.clublexus.com/forums/sho...d.php?t=198955
If you want the service manual excerpt for the entire procedure. I have it in my email box somewhere. Just PM me.
Good luck.
UZS160
Suspension
Aug 22, 2018 08:56 AM
djpauldc1
Oct 29, 2010 12:28 PM
amy011079
IS - 1st Gen (2001-2005)
36
Jun 11, 2007 04:02 PM
gs300_r1
GS - 1st Gen (1993-1997)
Feb 20, 2005 07:16 PM
Jwitty
Mar 31, 2003 10:14 AM
