LSD Install.
Took me about 6 hours. All in all a really easy swap . Car drives great no rear end noise etc... Limited slip works awesome. I was out drifting in the snow right after the install!
I had thought I was just getting the internal limited slip parts.But this is what arrived on my doorstep. A complete 3.76 LSD pumpkin out of a 95 auto supra! (sc300 rear is a 4.28)
I was stoked! and felt a little less ripped off by the $850 price tag.
So I unbolted the axles, drive shaft and the pumpkin on the stocker. Slid my tranny jack under the car and dropped the old pumpkin.
Then I swapped the companion flanges so the sc300 drive shaft would bolt up. (35mm deep socket)
I like how the LSD unit has cooling heat sinks on the bottom!
All cleaned up and ready to bolt back in!
Gotta hand it to toyota for the awesome design. That was so much less painful that I imagined!
Should see some nice MPG increases as well!
Ill keep U all posted.
*****Do not buy from this member until further notice *****
someone loves harbor freight.... lol welcome to the world of 2WD where both wheels love traction!!!!!! congrats keep it on the track!!!!!!
btw if u unbolt the heat shield and slide it towards teh rear of the car u can access teh driveshaft center bearing and remove the 2 bolts to make the driveshaft connect and disconnect easier!!!!!!
hey looks good, i just ordered my Kaaz LSD so ill be doing the same thing here soon. except im swapping the internals completely out. just wondering what did you use to get the bolts out. they look like allen head bolts am i right?
From: Sideways on the Yellow Brick Road! < Thats KS!
Harbor freight rocks!
Thats some good info on the drive shaft. I dropped a teste or two pushing it up in there at an angle to get the drive shaft lined up. The rubber bin was plastic wrapped to a crate and shipped through a trucking company. I had to pick it up becuause they couldn't get a semi through my neighborhood. Or so they claimed.
The car is really making nice progress! Cant wait to see it run at the track this summer!
axle shaft bolts are 10mm hex and the 3 rear bolts are 12mm hex
u can buy the entire hex set from 6mm-14mm at HARBOR FREIGHT FOR $8.99
it took you 6 hours to swap diffs? that a long time. it takes me 1.5 hours doing it all on my own. then i again i have plenty of practive with removal/replacement/welding/installing....about 3 times
nice upgrade id love to have one in my car. i dont mind welded diff. i mind females getting in my car and then asking why it jerks. lol.
