E-manage ultimate and map sensor
Old Jan 28, 2008 | 04:06 PM
WICKED 1's Avatar
WICKED 1
Default E-manage ultimate and map sensor
I am having problems. with my car ...not me
2jz-gte in a sc400
phoenix tuning did the harness and that works fine. when i cut the pressure sensor and tap in the e manage it says the input voltage is right but it wont output the right voltage. spliced back to stock then it runs better. any ideas?
Old Jan 28, 2008 | 04:23 PM
plex's Avatar
plex
1UZFE/2JZGTE
I'm not familiar with e-manage but shouldn't there an option to adjust the output voltage. Basically the stock ecu must be fooled into only thinking that a certain voltage is coming in. So since the e-manage is in between the actual signal and what's going to the ECU it should be able to tell the ECU the "right" voltage.
Old Jan 29, 2008 | 11:46 AM
WICKED 1's Avatar
WICKED 1
that does make sense. you are not the first person to tell me this. i have looked but i guess i will look again
yauny
Sep 19, 2015 08:36 AM
dubseven
Apr 9, 2015 10:47 AM
unknown101
Sep 28, 2014 05:12 PM
tampa mike
Mar 24, 2012 07:12 PM
