Gas pedal very sensitive from stop
Old Jan 19, 2008 | 08:18 AM
'99 SC 400's Avatar
'99 SC 400
Default Gas pedal very sensitive from stop
After many years of looking I have finally bought a 1999 SC 400. It has 120k miles Sil/Blk. Does anyone know how reduce the sensitivity of the gas pedal when pulling away from a dead stop?
Old Jan 19, 2008 | 09:48 AM
TheMole's Avatar
TheMole
Maybe throttle cable.
The following thread shows you how to tighten up the cable for better throttle response. I figure you can do the opposite to lessen the throttle response:
https://www.clublexus.com/forums/sho...d.php?t=326680
Old Jan 19, 2008 | 10:39 AM
'99 SC 400's Avatar
'99 SC 400
Thank you for the link. I have to think this over, but my first reaction is that this is the reverse of what I need. It's too responsive now. I think it's called tip-in. When you give it enough gas to pull out, it jumps, instead of a smooth pull away.
Old Jan 20, 2008 | 01:49 PM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
moving to performance section
Old Jan 20, 2008 | 07:54 PM
97-SC300's Avatar
97-SC300
usually its a good thing to ahve instant responce. lol
Old Jan 21, 2008 | 05:29 PM
Kruso's Avatar
Kruso
Haha... it is a good thing to have instant response. If you were absoluetely adamant about toning it down, you could retard the timning.
Kruso
Old Jan 22, 2008 | 05:52 AM
19psi's Avatar
19psi
you should feel lucky you have the high comp engine and better torque convertor than those of us with the older setups! really though, that's just how it is. after you get accustomed to the feel of the throttle pedal, you'll be able to modulate it better.
what did you drive before?
Old Jan 22, 2008 | 07:49 AM
Dx3's Avatar
Dx3
Never seen this before Usually people are complaining because they can't pull away fast.
You could lower your stall on your TC, or else just learn how to feather/better control your thottle.
Jonny
Old Jan 22, 2008 | 10:00 AM
VJZ's Avatar
VJZ
Must just like the DD style.
Can't blame you for that. I'm curious to see if the tighter cable affects MPGs.
Old May 25, 2023 | 09:36 PM
Honozoolu's Avatar
Honozoolu
5th Gear
Default I have same problem.
Car launches from stop. Doesn't always do it but when it does I try to lightly feather pedal it just grabs and goes. Accelerates smooth any other time. Was thinking vacuum leak? Cable throttle body gummed up? Any luck figuring out what was causing yours to launch from stop?
potatomon
Oct 12, 2018 04:01 AM
metalrocke
Mar 8, 2011 01:30 PM
Dueces
Dec 1, 2010 10:18 AM
Luxor
Nov 11, 2010 12:36 PM
IonFeright
Mar 31, 2009 01:19 PM
