Sc300 Hid
Old Jan 9, 2008 | 03:41 PM
tapatap33's Avatar
tapatap33
Default Sc300 Hid
Yea guys are there any thing special needed to be done to a sc300 to do a HID conversion.
Old Jan 9, 2008 | 03:52 PM
crx378's Avatar
crx378
no, just plug it in and enjoy!
Old Jan 9, 2008 | 04:21 PM
RedPhoenix's Avatar
RedPhoenix
sometimes you need to swap the positive and the ground wires on the harness that plugs into ballast. for mine I had to. Lexus reversed the wires from factory, I guess it doesnt matter in a halogen bulb setup.
Old Jan 9, 2008 | 05:27 PM
tapatap33's Avatar
tapatap33
Default thanks
Thanks a hole lot guys swapping the positive to negative worked but I only hope I knew that before I burn one of the bulb
Old Jan 10, 2008 | 12:48 AM
TheMole's Avatar
TheMole
Do a retrofit if you want sharper cut-off and less glare.
Old Jan 12, 2008 | 09:58 PM
halizm's Avatar
halizm
What brand are you buying ? Thinking about going HID too.
Old Jan 16, 2008 | 06:53 AM
XenonDepot's Avatar
XenonDepot
Former Sponsor
Hello,
Your vehicle uses a 9006 bulb for the low beams meaning that you would need to order a 9006 HID conversion kit for your vehicle. Here are some pictures of our 9006 5000k kit installed on the SC:
https://www.clublexus.com/forums/sho...d.php?t=287933
Steve
ns3425
Feb 9, 2008 11:46 PM
huerdo623
Lighting
18
Oct 8, 2007 12:37 PM
Handogen
Lighting
Jul 30, 2003 04:38 PM
