Engine Mount Replacement
I searched the forum on this but did not find anything. Can anybody provide guidance on either a how-to or point me to a URL where there are instructions? My car is a 1992 SC400.
Thank you!
Thank you!
Last edited by sydwys; Jan 5, 2008 at 11:58 AM. Reason: Forgot to include car model.
well if it is same as sc300 location, which i 80% sure it is. the you will the engine hoiste to lift the motor up off the frame after unbolting the 2 bolts from under the car. then i believe there are 2 or 3 bolts that hold it to the block, but i will double check.
pbbnxiltae
Nov 10, 2007 06:34 AM
vinny186
Nov 23, 2006 11:18 AM
