help! Key won't leave LOCK position! :(
Old Jan 1, 2008 | 09:42 AM
dopeyx27's Avatar
dopeyx27
Unhappy help! Key won't leave LOCK position! :(
hey everyone, I searched and couldn't find anything that would help. I have a 93 sc300 and the key won't turn in the ignition. The steering wheel is locked now too so I have go idea what to do. Tried moving the steering wheel and key around at the same time for about 2 hours but still no luck.
Happy new years everyone
Old Jan 1, 2008 | 09:47 AM
al4nek's Avatar
al4nek
That's weird, you should be able to turn steering wheel a little and than turn the key.
Old Jan 1, 2008 | 09:50 AM
dopeyx27's Avatar
dopeyx27
Ive tried that for 2 hours straight, still no luck =/ I turned the steering wheel every possible way, jiggled the key, moved it back and forth slowly etc. but still no lucky.
Old Jan 1, 2008 | 09:53 AM
sc250tt's Avatar
sc250tt
Is it the original key? Maby you bent it some how.
Old Jan 1, 2008 | 09:59 AM
dopeyx27's Avatar
dopeyx27
Yeah its the original key with the remote unlock/lock which doesnt work. Im thinking that the key might have been bent but the last time i started it was last week and it didnt struggle this much.
Old Jan 1, 2008 | 02:33 PM
unreal-'s Avatar
unreal-
CL Folding 10,000
Is the car in Park? That happened to me once.
Old Jan 1, 2008 | 03:04 PM
LRP_LS400's Avatar
LRP_LS400
make sure it's completely in Park
Old Jan 1, 2008 | 04:18 PM
joe diego's Avatar
joe diego
Was it in park?
Old Jan 1, 2008 | 04:57 PM
dopeyx27's Avatar
dopeyx27
yeah the car is in park for sure, I even did the shift lock and moved it to neutral and park
Old Jan 1, 2008 | 05:36 PM
BLK13X's Avatar
BLK13X
For Mind Cruising
Sounds stupid but is your foot on the brake when you try to switch the ignition on? Is there an aftermarket immobiliser stuffing around with you?
Old Jan 1, 2008 | 05:51 PM
dopeyx27's Avatar
dopeyx27
no everything is OEM, i tried pressing the brake, mov ing the steering wheel left and right, even has hard as i could. I even tried gently doing everything but still no luck.
Im going to try to get a copy of a spare and valey key for lexus tomorrow. Does anyone happen to know how much that would run me?
Old Jan 2, 2008 | 12:28 AM
F3DERAL's Avatar
F3DERAL
yeah that happened to me try to wiggle the shifter
Old Jan 2, 2008 | 07:28 AM
dopeyx27's Avatar
dopeyx27
Originally Posted by Win_Huynh
did you hold the brake down while turning the steering wheel and turning the key????
Yup...
msglength
Old Jan 2, 2008 | 08:10 AM
UTSC300's Avatar
UTSC300
this happened to me for about 20 min. I was scared ****less. I started punchin the console and nothin. It was so wierd cause no matter how hard u tried to pull it out it wasn't budging. finally whatever was holding it, just let it go like normal. hasn't happened since. good luck
Old Jan 2, 2008 | 08:20 AM
Seasian's Avatar
Seasian
I know on my car when I put it in park, I have to push up on the shifter again and it then clicks into place. Otherwise it wont turn off or let me take the key out.
