Rear trailing arm bushings
Old Nov 13, 2007 | 12:28 PM
Ezcompany's Avatar
Ezcompany
Default Rear trailing arm bushings
Please help! I have searched the forum extensively for someplace to buy relacement bushings for the rear trailing arms with no luck! I have excessive wear to the right rear tire even though the alignment is well within specs. The bushings would be for a 95 SC300. Appreciate all help.
Old Nov 13, 2007 | 03:33 PM
TT6SPDSC's Avatar
TT6SPDSC
www.tmengineering.net has bushing kits for the SC.
I'm wondering if you mean the lateral arm bushing though, the arm that runs front to back, not side to side. If that's the one you're speaking of and you need the bushing that's pressed into the knuckle you're probably out of luck. I'm not even sure if that busing can be bought from Toyota...You may have to replace the whole knuckle to get it.
Ok, Toyota is calling that arm a rear strut rod. The front bushing that presses into it is available from Toyota, the one in the knuckle is not.
Old Nov 13, 2007 | 03:48 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Maybe you didn't search in the correct forum
Moved.
Old Nov 14, 2007 | 11:05 AM
miraluna's Avatar
miraluna
ebay... there was couple ebayer who sells them for like 100+/-
Old Nov 15, 2007 | 09:20 AM
Ezcompany's Avatar
Ezcompany
Default Thank you
Thanks for the replies. Yes my workshop manual has them as being strut rods, however most people refer to them as trailing arms. Thanks again for all your help.
SCFactory
Feb 12, 2017 01:28 PM
StevieA
Dec 5, 2012 04:46 PM
Rey
Oct 6, 2011 07:57 PM
stockhatch
Dec 17, 2010 01:40 PM
en11871
Nov 21, 2010 08:14 PM
