Went N-AT and having problems
Old Nov 7, 2007 | 10:04 PM
VW_Vanagon's Avatar
VW_Vanagon
Default Went N-AT and having problems
Ok as the title says I went N-at and now I am having problems. It is a self put together kit using some DSM parts because I am working to get the money for the other stuff. But I ran the car with no O2's and i studders when I rev and studders when I hit boost. It is also running very rich when I am at WOT. am when I idle the Wide band is all ove the place some times at rich some times at lean. It also some times does not idle at all. The O2s are no hooked up and when I ran the codes I got a bad 24 and a 26. I also fixed the idle a little bit by bolting down the ECU a little better. Any help would help alot.
Old Nov 8, 2007 | 12:25 AM
gadgetSC's Avatar
gadgetSC
The stock ECU needs input from the O2 sensors, otherwise it will run like crap. You could install one and jumper the input to the the second sensor input.
gadgetSC
Old Nov 8, 2007 | 10:53 AM
VW_Vanagon's Avatar
VW_Vanagon
I have my O2s hooked back up tho.
Old Nov 8, 2007 | 11:21 AM
sphy1005's Avatar
sphy1005
how does it run now with the o2s hooked back up?
Old Nov 8, 2007 | 12:06 PM
Dx3's Avatar
Dx3
Would this not imply you have some loose wiring somewhere?
Jonny
Old Nov 8, 2007 | 04:58 PM
VW_Vanagon's Avatar
VW_Vanagon
Runs exactly the same.
Old Nov 8, 2007 | 04:59 PM
VW_Vanagon's Avatar
VW_Vanagon
Jonny
It ran the same when I tried to reground it tho.
Old Nov 8, 2007 | 05:04 PM
Bryan858's Avatar
Bryan858
Do you still have your map or mas? if its disconected or not pluged in it give the same symptoms your mentioning... - Bryan
Old Nov 8, 2007 | 11:35 PM
Sc dRifta's Avatar
Sc dRifta
*****Do not buy from this member until further notice *****
reset the ecu sounds like a boost leak to me. btw you only need 1 o2 sensor just splice them together and make sure they are far away from the turbo it will melt and cause a fire ask how i know lol.
oh and what the hell are you regrounding?
Old Nov 9, 2007 | 12:08 AM
VW_Vanagon's Avatar
VW_Vanagon
The ECU I heard that could be a problem with bad idle
New problem. Sometimes when I am driving it will all the sudden just die and go way lean and then start going again. Only on low throttle tho.
Also the check engine and trac light come on some time and the car dies a little at idle. and the CEL and trac light go way when I get about around 2500rpms
Old Nov 9, 2007 | 12:09 AM
VW_Vanagon's Avatar
VW_Vanagon
Tried it and the car would not run at all. could not rev and it would not idle.
Old Nov 9, 2007 | 12:56 AM
DryBlaze's Avatar
DryBlaze
I am running no O2's and my car runs good. lol
Old Nov 9, 2007 | 09:45 AM
VW_Vanagon's Avatar
VW_Vanagon
You arnt running any 02s at all?
Old Nov 12, 2007 | 01:17 AM
DryBlaze's Avatar
DryBlaze
No O2's at all on a stock ecu with no piggy back lol.
integgy
Apr 8, 2019 02:08 PM
1jzpickup
Aug 12, 2016 10:23 AM
BinaryJay
May 2, 2010 06:36 PM
fordsvtmfl
Performance
Feb 5, 2009 07:04 PM
