1JZ - Cannot Rev Pass 3000 RPMS - Need Guru.
Subscribe
Oct 25, 2007 | 08:11 PM
  #31
advance auto has them. However.. I would STILL get the CEL to work!
Reply 0
Oct 25, 2007 | 08:41 PM
  #32
i plan on it, wiring is just kindof daunting to me because i dont understand any of it or how it works... i wish i did
Reply 0
Oct 26, 2007 | 04:36 AM
  #33
haha, well ill be by later.
Reply 0
Oct 26, 2007 | 08:58 AM
  #34
Quote: i plan on it, wiring is just kindof daunting to me because i dont understand any of it or how it works... i wish i did
just cut the wires from the plug and connect them together .try using a pin to get the wires out from the clip
Reply 0
Oct 28, 2007 | 07:43 AM
  #35
so i wired the CEL and it lights up when i put the key to the "on" position but once the car is running, there is no CEL light, so now what do i do? I havent really got any idea of what to check next to get the car running. All the ECU wires are plugged in and i opened the ECU up and the computer board that is on top looks fine. What should i check next guys?
Reply 0
Oct 28, 2007 | 09:19 AM
  #36
did you change that cam sensor?
you can check for codes by jumping TE1 and E1 on the diagnostics port in the engine bay switch the car in the on position and count how many blinks the CEL gives.
Reply 0
Oct 28, 2007 | 09:51 AM
  #37
didnt change the sensor because i think it is ok. the car wont start if the sensor is unplugged, but will if it is plugged in so wouldnt that mean it is working?
Reply 0
Oct 28, 2007 | 12:25 PM
  #38
Now that the CEL is working, the next step is to run the codes, as shlounek said. Here is a link showing how to do it (in a Celica, it's the same deal).
Let us know what comes back!
http://www.celicatech.com/imagearchi...ac/FI/FI21.htm
-Doc
Reply 0
Nov 4, 2007 | 03:05 PM
  #39
so i was checking the ECU wires today and i noticed that there was a pink wire on one of the ECU plugs that was T-tapped with a purple wire that ran about an inch and a half and was cut after that, i have no idea if this has anything to do with anything but i wanted to check with you guys first.
Reply 0
Nov 4, 2007 | 03:21 PM
  #40
What pin is it going to?
Did you run the codes yet?
-Doc
Reply 0
Nov 4, 2007 | 04:41 PM
  #41
didnt get a chance to run codes yet, and how do i know what pin it is?
Reply 0
Nov 4, 2007 | 04:50 PM
  #42
Make it a priority.
Well, if you don't know how to read the pinout, then take a picture and I can tell you.
-Doc
Reply 0
Nov 4, 2007 | 05:02 PM
  #43
ok, its just hard to get to because the plugs are up under the dash, so i cant really see where the wires are going in to
Reply 0
Nov 5, 2007 | 04:29 AM
  #44
take out the plug and try finding an ecu pinout
*edited*
Reply 0
Nov 5, 2007 | 06:25 AM
  #45
^^ that's a supra ecu pinout, the soarer/chaser has 4 rows.
Reply 0
