1JZ - Cannot Rev Pass 3000 RPMS - Need Guru.
Old Oct 23, 2007 | 09:07 PM
CCC-TT's Avatar
CCC-TT
Originally Posted by sc300gte
I had the exact same problem as you. I'd say check ALL of your grounds, and your ecu wiring. My problem was a loose ecu wire that was grounding out. Caused the same problems that you described. Also, it caused the ecu to fully retard the timing, thus totally destroying my turbo (super hot egt).
hmmm... my turbos (one or two) are bad, all i can say is hmmmm...?
Old Oct 24, 2007 | 07:00 AM
sc250tt's Avatar
sc250tt
This is what the ecu does when it is running in limp mode it will not rev past 3000 rpm . if you keep trying to make it rev past that you will melt a piston ,trust me ive seen it tons of times with these engines .your best bet is cheack your wiring because this is usually caused by bad wiring, the ecu should be fine sice he did not extend the ecu harness there,Is the cel light wired up? if not its a blue wire with a yellow stripe on the 1jz harness which have to connect to the blue/yellow wire on the sc bodyplug .Grounds will not cause this a bad sensor or improper wiring will cause this .
Old Oct 24, 2007 | 07:05 AM
RedPhoenix's Avatar
RedPhoenix
The CEL isnt wired up. Im guessing that this will be TOP priority today to do.
Old Oct 24, 2007 | 09:27 AM
Rexn30's Avatar
Rexn30
Whats the CEL plug stand for?
Old Oct 24, 2007 | 09:30 AM
RedPhoenix's Avatar
RedPhoenix
check engine light
Old Oct 24, 2007 | 02:28 PM
Rexn30's Avatar
Rexn30
Ah ha, I feel retarded now.
Old Oct 24, 2007 | 07:12 PM
RedPhoenix's Avatar
RedPhoenix
Bobby, I got 2 more for you.
Check your plugs, see if any are completly killed... even a tip broke off or something
Check your injectors. Let it idle and pull off the clip on each one. If the motor sound DOES NOT change, there your problem.
Old Oct 24, 2007 | 07:43 PM
CCC-TT's Avatar
CCC-TT
good thinking, i'll try it tomorrow. I didnt get a chance to do anything today because i'm a little on the sick side. left school at 9:30 and slept all day. I'm also going to wiggle that cam position sensor around and see if it changes sounds like it did when dan did it
Old Oct 24, 2007 | 08:16 PM
RedPhoenix's Avatar
RedPhoenix
Yeah, feel better. It was raining all day too, hard to work on the car ya know?
Ill see you Friday after work.
Old Oct 25, 2007 | 12:35 PM
CCC-TT's Avatar
CCC-TT
how did you guys get to the blue/yellow wire on the female side of the bodyplugs, it seems almost impossible to get to?
Old Oct 25, 2007 | 01:46 PM
CCC-TT's Avatar
CCC-TT
so i unplugged the coilpacks one by one while the motor was running, each time one was unplugged, you could notice the difference, so i believe they are all working. I pulled out the cam angle sensor that is right near the injectors, when i pulled it out, the car was running, i pulled it and nothing changed, i looked in it and it was filled with oil over the electrical pins on both sides and there was oil sitting in the bottom of the female side. I cleaned it and plugged it back in, no fix, so i pulled it out and revved it up with the sensor unplugged, no difference. So is this my problem? keep your fingers crossed that it is, now i need to figure out where to get a new one
Old Oct 25, 2007 | 03:29 PM
shlounek's Avatar
shlounek
Maybee that is the problem, Mine has that exactly same sensor and its flooded with oil also, I have new cam sensors but the flu just hit me, and i cant put them and test until this flu clears.
I hope this fixes your problem.
Old Oct 25, 2007 | 05:44 PM
CCC-TT's Avatar
CCC-TT
where did you get your cam sensors? will the 2jz ones work?
Old Oct 25, 2007 | 06:14 PM
LexusFTW's Avatar
LexusFTW
i know 2js can run with only one cam sensor. do 1js have one or two sensors? did you pull them both?
Old Oct 25, 2007 | 07:51 PM
shlounek's Avatar
shlounek
you can find them new at, make sure you search it under 2jz autozone or murray's.
2j's and 1jz's use the same CPS and there are 2 of them
