I installed a <MY97 spoiler on my then spoiler-less trunk and I came across a neat trick through my searches (AHEM). Someone advised to put grease (i used white liquid hand soap) on the tips of the bolts that stick out the bottom of the wing. Position, give it a tap on the trunk, and viola! marks for your drilling pleasure! Gave me much more confidence when busting out the drill...
remember to install it pushed back as it should be OEM with a slight overhang, many 97 spoilers are installed incorrectly lined up with the rear of the car up too far on the lid...i know first hand when i had one on mine installed.
For what it would cost in shipping it probably wouldn't be worthwhile...
Good tip - thank you
So it should overhang and not be flush with the edge of the trunklid? How much overhang are we talking? Do you have any pics?
Does the module just stop the light on my dash from coming on? If so, I am not worried about it - I already have most of them on anyway
Does the plug from disconnecting the sub cover brake light plug into the spoiler? Or is the spoiler one just hanging in there?
Thanks man,
Jonny
Yes, that is all the module does. The spoiler connector is different from the sub cover brakelight connector. It will be hanging there, maybe tied or something- it's been a while.
