Over Drive Problem Thread (Merged)
Old Jun 28, 2006 | 02:25 PM
dinhNER's Avatar
dinhNER
Default Over Drive Problem Thread (Merged)
whats the problem when the O/D light keeps flashing ?
i dont get it
thanks in advance if any one would give me advice and info on it
Old Jun 28, 2006 | 02:42 PM
SC400DAVE's Avatar
SC400DAVE
Is it on or off? The o/d that is
Old Jun 28, 2006 | 03:03 PM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Torque convertor.
Old Jun 28, 2006 | 08:29 PM
atekt's Avatar
atekt
Originally Posted by O. L. T.
Torque convertor.
Dont tell me that! Sorry to jack the thread but any clue on where to purchase a Converter for the soarer tranny?
Old Jun 30, 2006 | 09:07 AM
O. L. T.'s Avatar
O. L. T.
Keeper of the light
Well that is not the ONLY cause, but it is one of the largest reasons. The other is the shift solenoid. Either way it needs to be put on a REAL scanner to see what is up. My Snap On scanner will diagnose the tranny.
Old Jul 1, 2006 | 10:38 PM
dinhNER's Avatar
dinhNER
oh i see to bad im in HOUSTON,TX lol
Old Jul 7, 2006 | 07:06 AM
k7mx's Avatar
k7mx
Default O/D light flashing
My SC400 has the same symptom. It indicates an error code 67 from the tranny and this is usually the result of a bad speed sensor. Have it checked by the dealer...it could be just a bad connection on the sensor. They're not too expensive to replace if its bad.
Good luck
Don
Old Jul 7, 2006 | 06:05 PM
hybridrift's Avatar
hybridrift
this also happened to me two weeks ago, my check engine light came on and then the O/D light started flashing. Next thing you know theres a loud back-fire sound and and its puttin down the road like theres a hole in the exhaust.... Next morning checked it out, the number 2 spark plug blew out. I replaced the plugs and rethreaded the #2 reset the ecu and it was fine after that....
hybridrift's Avatar
hybridrift
Also, did you recently hook up a safc????
Old Sep 6, 2006 | 01:49 AM
Blu92SC4's Avatar
Blu92SC4
I had the same problem of the O/D light blinking on/off intermittently on my 92SC400. I had a friend who used to work in the Lexus service department and his buddy hooked me up to the scanner. The code that showed up was for Solenoid #2 (code number 72 I think) . I tried to do some research on it and saw on a Toyota Service Manual (not sure if it applies to all models) that Solenoids 1 & 2 controls gear shifting and I noticed that sometimes in first gear the engine will rev up to past 3-4K RPM before shifting to 2nd. It says that if either one fails that the other one will serve a back-up function.
I'm wondering if this is applicable to our cars and if so
1.) How long can I go before fixing it?
2.) What are the potential complications from not getting it repaired soon;can I live with it for now without worrying about something worse happening?
3.) What are my options for getting this fixed and potentially how much $$$? (Would I have to repair, rebuild, or replace tranny)
Thanks guys for any input.
Old Sep 6, 2006 | 07:42 AM
sc250tt's Avatar
sc250tt
if the car is moving really lazy its the solenoid
Old Sep 6, 2006 | 01:04 PM
CantSeeMe's Avatar
CantSeeMe
It does apply to our cars. You can ignore or "live" with it for quite a while. But it gets more and more frequent. It almost drove me insane.
https://www.clublexus.com/forums/sho...d.php?t=233720
Old Sep 7, 2006 | 09:48 AM
bruce van's Avatar
bruce van
Blu92SC4, if you are in So. Cal, I know a good shop I got my work done at. PM me if you have any questions.
Old Sep 8, 2006 | 01:15 AM
Blu92SC4's Avatar
Blu92SC4
Thanks 4 the info
Old Sep 10, 2006 | 06:32 AM
udfxrookie's Avatar
udfxrookie
I have the same problem... when I check the code out on my 92 SC400 it shows code 61... what's that mean?
