Over Drive Problem Thread (Merged)
Old Sep 10, 2006 | 09:27 AM
dinhNER's Avatar
dinhNER
Originally Posted by Blu92SC4
I had the same problem of the O/D light blinking on/off intermittently on my 92SC400. I had a friend who used to work in the Lexus service department and his buddy hooked me up to the scanner. The code that showed up was for Solenoid #2 (code number 72 I think) . I tried to do some research on it and saw on a Toyota Service Manual (not sure if it applies to all models) that Solenoids 1 & 2 controls gear shifting and I noticed that sometimes in first gear the engine will rev up to past 3-4K RPM before shifting to 2nd. It says that if either one fails that the other one will serve a back-up function.
I'm wondering if this is applicable to our cars and if so
1.) How long can I go before fixing it?
2.) What are the potential complications from not getting it repaired soon;can I live with it for now without worrying about something worse happening?
3.) What are my options for getting this fixed and potentially how much $$$? (Would I have to repair, rebuild, or replace tranny)
Thanks guys for any input.
thats the same thing my car does
Old Sep 10, 2006 | 06:23 PM
udfxrookie's Avatar
udfxrookie
Anyone? Code 61?
Old Sep 10, 2006 | 10:54 PM
dinhNER's Avatar
dinhNER
i dont even have time to check for the code
Old Sep 11, 2006 | 07:32 AM
sc250tt's Avatar
sc250tt
dinhner is your car a 400?
Old Sep 11, 2006 | 10:17 AM
dinhNER's Avatar
dinhNER
yes sirr its a 400
Old Sep 11, 2006 | 11:38 AM
sc250tt's Avatar
sc250tt
thought it was a 300 my 300 was doing the same thing and it was the solenoid .it might be the same issue with yours .not to sure tho
Old Sep 11, 2006 | 11:46 AM
CantSeeMe's Avatar
CantSeeMe
Originally Posted by udfxrookie
Anyone? Code 61?
#2 speed sensor .
Old Sep 11, 2006 | 11:52 AM
CantSeeMe's Avatar
CantSeeMe
Originally Posted by dinhNER
yes sirr its a 400
Your car is an OBD1 ? It wont take you more than 5 minutes......It will probably take you more time to find a paperclip...
Old Sep 11, 2006 | 08:46 PM
udfxrookie's Avatar
udfxrookie
#2 speed sensor on tranny? Or is it a sensor I can change myself?
Old Sep 11, 2006 | 10:29 PM
dinhNER's Avatar
dinhNER
my house doesnt have **** in it, by that i mean office supplies lol
Old Sep 12, 2006 | 08:45 PM
udfxrookie's Avatar
udfxrookie
#2 speed sensor is noted as the overdrive speed sensor on the tranny.... I'm ordering one from Lexus for $110... is it something I can just jack the car up, and swap out or what? Plus my O/D light isn't on or flashing anymore.... does that mean everything's fine now or what?
Old Sep 12, 2006 | 10:58 PM
dinhNER's Avatar
dinhNER
let me know how that works out for you udfxrookie
Old Jan 5, 2007 | 12:23 PM
snshn1314's Avatar
snshn1314
Have a bit of a similar problem, first got a check engine light, checked that out to be a code 17 (CMP No.1) reset the code then after about 30 miles of driving came back on and then went off. Shortly after got the flashing O/D light, if I take the car into autozone/checkers will they be able to tell me exactly what the problem is?
Old Sep 21, 2007 | 01:49 PM
want sc300's Avatar
want sc300
Default Over drive not engaging.
transmission is acting up on my 1992 sc300
just recently i lost 4th gear the tranny just wont shift into 4th (O/D)
some time it will shift into 4th but a few seconds later it will kick back into 3rd
im thinking sensor going bad but i dont know which one
and i dont know what the two sensors on the tail end of the tranny are called. so i cant get diag procedures for them.
Old Sep 21, 2007 | 02:02 PM
sc250tt's Avatar
sc250tt
probably a bad solenoid .Diagnose the tranny by connecting te1 and e1 if i remember right those are the two pins you bridge with a paperclip
