Need help with AC
Old Aug 13, 2007 | 11:45 AM
marek955i's Avatar
marek955i
Default Need help with AC
I recently picked up a 1995 Lexus sc and this past Friday my ac stopped working. The heat does not work either. Has anyone here ran into this problem? I called a Lexus deal and they told me to bring the car in. Just wanted to see if anyone knew a fix before i take it to the dealer. The fan just blows hot air when its hot and cold air when its cold outside.
Thanks
Old Aug 13, 2007 | 01:32 PM
jefferino's Avatar
jefferino
dealer gonna kill you with $$ Sounds like you need a re-charge of your a/c system. I'd check out mom-n-pop places first... Thats what I did and paid alot less than a dealer would have raped me with
Old Aug 13, 2007 | 02:17 PM
acenase's Avatar
acenase
Your AC needs to be re-charged. I had the exact same problem, whenever I turned my AC on, it just blew air...wasn't cold at all. Go to like Jiffy Lube or something instead of the dealer.
Old Aug 13, 2007 | 02:29 PM
habitat's Avatar
habitat
How about the Heater Control Valve? SC are prone to these unhooking thus leading to worse problems. Although this solution is more attributed to your heater not working.
Old Aug 13, 2007 | 02:37 PM
udstuengt's Avatar
udstuengt
Your compressor could also be malfunctioning.
To check this, start your car, turn the AC on. If you hear the car idle up (Meaning the engine revs higher), your compressor works and is most likely just a recharge.
Old Aug 13, 2007 | 11:35 PM
hybridrift's Avatar
hybridrift
Thanks
Please be more specific. Did the blower go, or just no cold or hot air?
Old Aug 14, 2007 | 01:28 PM
Fireblaze's Avatar
Fireblaze
No cold air most likely means that you need to be recharged, but there has to be a reason why the freon left in the first place. The dealer will also inject it with a U.V dye that will show where the leak is. You will probably need some components to be changed.
As for the heater, it could be the valve or coolant level. Do a search and you will see many DIY's on how to fix the heater valve.
Old Aug 14, 2007 | 01:35 PM
fwynn's Avatar
fwynn
just go to walmart.. buy the recharging kit for like 50 bucks and ur set (comes with everything u need)
Hermyherm
GX - 1st Gen (2003-2009)
15
Aug 28, 2023 03:34 AM
mattham912
IS - 1st Gen (2001-2005)
Aug 21, 2009 11:44 AM
XSTeknique
Jun 7, 2006 12:40 PM
stallion50
Mar 23, 2006 05:44 PM
