shock removal ?
Old Aug 13, 2007 | 10:28 AM
DRFT103's Avatar
DRFT103
Default shock removal ?
what is the easiest way to take out the front shocks and springs? i've done sr20 swaps and have done full suspension work on my s13, but i cant figure out the easiest way to remove the front shocks on the sc. i tried a spring compresser but no luck... figured i'd ask you guys first before i take off the upper control arm haha.
Old Aug 13, 2007 | 01:40 PM
DRFT103's Avatar
DRFT103
bump anyone?
Old Aug 13, 2007 | 02:24 PM
mkorsu's Avatar
mkorsu
Zombie Slayer
No need to remove upper control arm completely, just undo the rear bolts.
You need to remove the lower shock mount from the lower control arm and the upper mount from under the hood. The entire shock and spring come out as one unit. Then use the spring compressor before removing the top cap over the spring.
Read through this. A simple use of the search function put this right at the top!
https://www.clublexus.com/forums/sho...ilover+install
Old Aug 13, 2007 | 05:51 PM
Blizzy's Avatar
Blizzy
un-do the UCA bolt. It is a bastard of a bolt to break free. The UCA will now want to slide out.
before you do this, make sure the ABS sensor wire is removed from the UCA itself (a couple bolts) and that you have something to suspend the hub other than the brake line (like a wire coat hanger).
At this point, loosen the three bolts on the top mount of the shock/spring assembly and then the big one at the bottom.
On the driver's side, you have to remove the windshield washer fluid jug to clear the UCA bolt. On both sides, you need to remove the inner fender lining.
The walkthrough that was linked to above is a great DIY with pictures to boot.
Old Aug 15, 2007 | 11:27 PM
Sc dRifta's Avatar
Sc dRifta
*****Do not buy from this member until further notice *****
nicely said remember to unbolt your washer tank to get the upper bolt off use a breaker bar and wd40. after that its easy to muscle out
Old Aug 16, 2007 | 04:28 PM
Rondawg's Avatar
Rondawg
Since I just changed out my shocks and springs 2 weekends ago and I didn't remove or unbolt any control arms, so I'll said that there's no need to remove the UCA.
All you need to do is remove the 19mm nut and bolt from the bottom of the shock, disconnect sway bar from the bracket on the LCA, remove the bracket that holds the bottom of the shock and sway bar on the LCA(just 2 bolts, swivel socket would come in handy here), undo the 3 nuts holding the shock/spring on top and you'll be able to remove the whole shock/spring assembly. Oh, I removed the caliper just to make it easy to slide the assembly out.
Hope this helps!
mad_trbo
GS - 1st Gen (1993-1997)
14
Aug 29, 2023 03:43 PM
SVTRondogg
Suspension and Brakes
Jun 17, 2015 01:49 PM
sjt0017
Suspension
Jun 1, 2014 01:37 PM
Sc4Love
Apr 29, 2010 09:18 AM
dale88
Nov 11, 2002 07:58 PM
