Bobbing Shifter... is this normal?
Old Aug 6, 2007 | 02:49 PM
Member1115's Avatar
Member1115
Default Bobbing Shifter... is this normal?
I just noticed something this past week regarding the shifter on my 92 SC400. As I am driving down the road or on the freeway, its seems to be bobbing (if that's the correct word to use). What I mean is that the shifter handle is moving back and forth rythimatically.
Now I am not sure if this was going on before, or if the situation just appeared after I installed the new wheels and tires, or is this a normal thing that happens. I was running stocks before, but jumped into 18's.
I figure if its not a normal thing or not a usual affect of having aftermarket wheels and tires, then it could be my tires arent properly balanced or something along those lines. But before I have that checked out and pay for such, I just want to confirm if this is or is not a normal behavior pattern on these cars.
Any feedback will be greatly appreciated.
Thanks everyone!!!
Old Aug 6, 2007 | 03:05 PM
100mgbluep's Avatar
100mgbluep
Mine also has a lot of play, it wiggles so much side to side that it feels like a shifter from a manual that is in neutral.
Old Aug 6, 2007 | 03:07 PM
mkorsu's Avatar
mkorsu
Zombie Slayer
Vibration from the trans. Most likely, the transmission mount is toast. Replace that and you're good to go!
Old Aug 6, 2007 | 04:03 PM
neurocity's Avatar
neurocity
Not quite my tempo
You can do a quick check, jack up the rear end of the car, both wheels off the ground. Lay under the car with a huge Flathead screwdriver or pry-bar. There is a little area between the mount/trans and cross member. Using the screw drive/pry-bar, wedging the blade in that spot, move the trans up and down. You'll be able to see if the rubber is broke or separated from the plate.
Mine was really bouncy, but still together...I'm at 60k, so you have a reference to go from as far as longevity
Off we go to the Engine/Trans section.
Old Aug 6, 2007 | 04:08 PM
100mgbluep's Avatar
100mgbluep
My shifter doesnt vibrate while driving its just really lose. I know my tranny mount is good because i checked it yesterday and the rubber was still intact without any cracks. Could it just be a lose bolt somewhere that i have to tighten?
Old Aug 7, 2007 | 12:01 PM
100mgbluep's Avatar
100mgbluep
anyone know how to fix this?
Old Aug 7, 2007 | 01:14 PM
sc250tt's Avatar
sc250tt
replace bushings in shifter assembly goodluck
Old Aug 7, 2007 | 01:40 PM
RX729's Avatar
RX729
I agree, It should resolve your bobbing problem...
Old Aug 7, 2007 | 01:56 PM
100mgbluep's Avatar
100mgbluep
Anyone care to explain how to do this? Anyone have any pics or w/e?
Old Sep 1, 2007 | 01:29 AM
Member1115's Avatar
Member1115
Anyone...?
Old Sep 1, 2007 | 04:01 AM
97-SC300's Avatar
97-SC300
mine does it also, i have new motor mounts and a new trans mount and still the same. anyoe know anything about these shefter bushings.
Old Sep 5, 2007 | 02:47 PM
100mgbluep's Avatar
100mgbluep
I found out the part is only $2 from toyota, i was trying to figure out how much they would charge to install them buti i got cut off so i need to call again i guess.... If it isnt hard and i have a write up to go by i would just do it myself..
Old Sep 5, 2007 | 06:02 PM
97-SC300's Avatar
97-SC300
what is teh part name and part number for these bushings. is there more then one?
Old Sep 5, 2007 | 07:20 PM
100mgbluep's Avatar
100mgbluep
There are a total of 2, one on each side.
Old Sep 5, 2007 | 07:59 PM
97-SC300's Avatar
97-SC300
What is the part number?
