Electrical Problems?
Old Jul 26, 2007 | 04:14 AM
jpvarghese's Avatar
jpvarghese
Default Electrical Problems?
I don't know what's causing this. My SC is a '99 model. Both driver and passenger side window are slow to bring up as well as the sunroof. Coming down really isn't a problem, but you could see it slowing down when raised back up. My sunroof is one touch when I open, but when I'm holding the button to close it, it stops halfway, then I have to hold the button again to have the sunroof close completely from the halfway point. Could this be an alternator issue or a weak motor? It feels like the latter. Lastly, my passenger side window rolls down without a problem when engaging the switch from either the driver/passenger side, but I cannot raise the window from the passenger side, but raises only from the driver's side. I do notice, however, that the switch on the passenger side feels loose. Hard to describe, but when raising from the driver's side if feel a little click, pushing or pulling, but from the passenger side its completely loose. So could this be a switch issue or could it be remedied with a fuse change.
Old Jul 26, 2007 | 05:44 AM
TheMole's Avatar
TheMole
Not sure about your windows, but your sunroof is supposed to stop halfway for safety issues.
Old Jul 26, 2007 | 06:01 AM
BLK13X's Avatar
BLK13X
For Mind Cruising
Could be a dying window regulator. How's the condition of your battery?
Old Jul 26, 2007 | 06:06 AM
sc250tt's Avatar
sc250tt
yea the 97 +sunroof closes halfway like the others for a safety reason.if you battery is good try spraying some silicone spray in the tracks . always help
Old Jul 26, 2007 | 06:30 AM
jpvarghese's Avatar
jpvarghese
I'm under the assumption that once the car is running, the battery is really not in use. So would this be irrelevant?
Old Jul 26, 2007 | 06:48 AM
sc250tt's Avatar
sc250tt
for the sc's yea its irrelevent for some reason the car uses the battery power and not just the alternator
tnc110
Nov 26, 2016 06:18 AM
9000revs
Jan 17, 2015 05:05 AM
Lex1992
Jul 2, 2012 07:01 AM
Cranbery
Feb 6, 2012 10:55 PM
dpakman91
Aug 28, 2002 01:41 AM
