A hello and a code 71
Old Jul 18, 2007 | 08:41 PM
93MSB's Avatar
93MSB
Default A hello and a code 71
Hello everyone, im new to the board and i just purchased a black SC300 w 142k miles this monday in houston for $4500. I also own a 93.5 N/A Supra so i know the drivetrain well.
I ran seafoam through the engine this afternoon and after driving around for about 30min the check engine light came on. I checked it and it threw code 71 which according to my supra manual is an EGR malfunction. I reset the ecu and the CEL hasnt come back on. Im assuming the codes are the same for each car, can someone confirm that code 71 is an EGR malfunction?
thanks,
rich
Old Jul 18, 2007 | 08:44 PM
neurocity's Avatar
neurocity
Not quite my tempo
Welcome, Check in the engine forum, I'm sure there are a few threads about engine code.
Old Jul 18, 2007 | 08:47 PM
SCpwner's Avatar
SCpwner
CL Folding 10,000
this website confirms that it is an EGR malfunction.
http://www.troublecodes.net/Lexus/
Old Jul 18, 2007 | 08:51 PM
na4now's Avatar
na4now
Id NEVER put that stuff in my engine.
Old Jul 18, 2007 | 08:52 PM
93MSB's Avatar
93MSB
thanks guys! i forgot about search, its been down so long at supraforums i forgot there was such a thing
SCpwner thanks for the link, that confirms my question
Old Jul 19, 2007 | 01:31 AM
$C300's Avatar
$C300
its 90% EGT sensor, i have that too, if u keep resting it, its just going to come back on after X amount of miles, and the interval will just shorten.
Old Jul 19, 2007 | 06:55 AM
sc250tt's Avatar
sc250tt
yea my sc300 did it every time i jumped on the highway .i removed the egr system and used a 1/2 ohm resistor and problem solved
Old Jul 19, 2007 | 09:02 AM
93MSB's Avatar
93MSB
yeah it came on again this morning, so im gonna remove it sometime soon
Old Jul 19, 2007 | 09:28 AM
link13's Avatar
link13
Vacuum modulator is a likely cause of error code 71.
Old Jul 20, 2007 | 12:40 AM
$C300's Avatar
$C300
Are you sure, my scanner sead EGT Sens.
Old Jul 20, 2007 | 10:32 AM
link13's Avatar
link13
I doubt your sensor is wrong. I had a code 71 CEL a few years ago. My brother cleaned the EGR valve and lines and it was fine for a while. The CEL came back after a few months and it was intermittent. I described the symptoms to the mechanic when I had my 120K mile service done and he said it was most likely the vacuum modulator. He tested it and it was faulty. I find a general code that says "EGR malfunction" to be a bit frustrating.
Old Jul 22, 2007 | 12:59 PM
Supra Dr's Avatar
Supra Dr
Moving SC Threads
If you don't feel like testing the system & want to try a quicky.
Remove the temp sensor & clean it off. The end gets carboned up
& the temp value is incorrect. (the carbon insulates the sensor tip
from reading true exhaust temp)
diverchris
Dec 27, 2010 07:43 PM
desol11
May 8, 2008 02:40 PM
ridah
Maintenance
Apr 7, 2004 10:44 PM
GOLDSc300
Maintenance
Dec 25, 2003 07:11 PM
93LexMojo
Jun 2, 2003 08:45 AM
