Loose stearing
Old May 22, 2007 | 09:14 PM
tritron's Avatar
tritron
Default Loose stearing
It seems that my steering is loose jave to turn my steering more to get it to turn that my other car. How I can fix it?
Old May 23, 2007 | 01:55 AM
vinh's Avatar
vinh
steering rack mount bushings / control arm bushings
Old May 23, 2007 | 04:37 AM
tritron's Avatar
tritron
do i rebuild it then or replace
Old May 23, 2007 | 10:58 AM
chanh55's Avatar
chanh55
They're shot. You have to replace them.
Old May 23, 2007 | 12:35 PM
markesc's Avatar
markesc
I had the same problem, replaced the steering rack bushings along with new control arms, it's a night/day difference, especially if you're running coilovers as well. The mechanic showed me the old bushing, it's just too soft and basically built to fail within 60-70k miles....go with the daizen kit!!
Old May 23, 2007 | 03:55 PM
tritron's Avatar
tritron
how much will cost me for labor to get it replaced.
Old May 23, 2007 | 04:39 PM
markesc's Avatar
markesc
Well that's hard to say,
I got all this installed for $800:
New Lower Control arms for the front, daizen front and rear camber kits, front and rear swaybar bushings by daizen, steering rack bushing, and alignment
There is a how to on just the steering rack somewhere on this forum...
I'm guessing the steering rack bushings should be pretty cheap as the install is rather straightforward if that's all you're looking at...
Old May 23, 2007 | 08:07 PM
tritron's Avatar
tritron
I was told that it takes 10 hours to replace brushings, 3 hours to remove each side 2 hours to replace ruber parts and 3 hours to put it back.
akafixture
Suspension and Brakes
Nov 10, 2014 08:05 AM
hovsc400
Aug 24, 2011 07:45 AM
jbw
13
Aug 12, 2007 10:14 PM
movinquick
51
Jun 26, 2007 06:30 PM
indypwr
Apr 17, 2005 04:02 PM
