1jz help needed
Old Apr 22, 2007 | 01:02 PM
atekt's Avatar
atekt
Default 1jz help needed
since i recieved no info at supraforums i thought id post it over here, just dropped my new 1jz into the sc and it will not start we have fuel spark and the timing is correct whats next?
HELP!!
Old Apr 22, 2007 | 03:22 PM
Sc1UZ-FE's Avatar
Sc1UZ-FE
cold Start injector?
Old Apr 22, 2007 | 07:16 PM
atekt's Avatar
atekt
what is the cold start injector? and where is it located?
thanks
Old Apr 22, 2007 | 08:12 PM
Rising_Sun's Avatar
Rising_Sun
Check the ECU. Whats the part number?
Old Apr 22, 2007 | 08:47 PM
tavarish's Avatar
tavarish
how do you have fuel and spark and the car doesn't start?
Old Apr 23, 2007 | 05:47 AM
sc250tt's Avatar
sc250tt
it has to be something minor if you are getting fuel and spark .did you extend the bodyplugs only? power up the two big orange wires on the bodyplugs most of the time with these swaps those wires dont get current and make you think its a big issue .bypass the fp ecu behind the rear left panel .if your car dont start then its something with the ecu or the harness you extend
Old Apr 23, 2007 | 10:21 AM
atekt's Avatar
atekt
harnesses are all extended properly, here is what we have done,
had a soarer 1jzgte in the car running etc drove it for about six months no isssues, tore it down to build it and do a big single (still in the process) so we picked up another 1jzgte low mileage no ecu etc but it was from a supra to get the car back on the road, so we pulled the soarer 1j out and took everything we needed and put it on the supra 1j (oil pan, water pump, harness, throttle body,etc) got it all dropped back in and this happens.
which plug are the orange wires located in under the dash i presume, and thefp ecu in the panel in the left rear how do we by pass it etc. i assume when you say left you mean drivers correct?
Thanks!!
Old Apr 23, 2007 | 10:42 AM
sc250tt's Avatar
sc250tt
yea the fp ecu is on the driver side .the two wires running to the bodyplugs thats for the coilpacks injectors etc,did you use the soarer intake mani or the supra
Old Apr 23, 2007 | 10:50 AM
atekt's Avatar
atekt
how do we by pass that fp ecu? and the orange wires, were just supposed to put 12v to them? what does this do? i believe we used the supra intake manifold with all the soarer stuff on it tps etc, we looked at them and they didnt appear any different, are they?
Old Apr 23, 2007 | 10:51 AM
atekt's Avatar
atekt
Correction. The Soarer Intake mani was used.
westboost
Dec 27, 2015 05:55 PM
DirtySc300
Sep 28, 2015 08:45 AM
Golden95SC
Feb 11, 2014 05:29 AM
empera
Aug 26, 2010 11:09 AM
got-sc?
Feb 15, 2010 09:37 PM
