1jz no start problems
Old Aug 20, 2010 | 10:34 PM
empera's Avatar
empera
Default 1jz no start problems
so i just dropped in a 1jz out of a running mk3 supra...only things i did was change the timing belt, change the injectors to 550s with a resistor along with a engine harness and i'm trying to use a chaser ecu.
The engine cranks but does not start. Doesn't look like im getting spark, fuel pulse or fuel pump....
any ideas?
Old Aug 20, 2010 | 11:20 PM
Dr.Fate's Avatar
Dr.Fate
Wow! did the motor run off the chaser ecu in the mk3? I think you might want to ask BigWaveSC his sc is running off a chaser 1jzvvti and he might be able to help you.
Old Aug 20, 2010 | 11:27 PM
onejapman's Avatar
onejapman
i would check timing again, no spark is usually means the timing is bad, try to pull one of the spark wires out and tap it to ground when cranking to see if it is sparking
Old Aug 21, 2010 | 06:56 AM
empera's Avatar
empera
no i used an mk3 1jz ecu and harness before but i had to change those 2 things going into the sc....
i used a spark tester and had no spark....i checked the timing and seems to be correct unless you can be 180 off with these engines....but even if the timing was off wouldnt it still try to fire?
also there is not CEL
Old Aug 21, 2010 | 05:04 PM
StiCk3's Avatar
StiCk3
sounds like a fried ECU. Is the ECU getting any power at all?
Old Aug 21, 2010 | 06:08 PM
empera's Avatar
empera
i think so, im also thinking its ecu...
i just need another ecu to try or someone to try my ecu on theirs....what ecu are you using?
Old Aug 21, 2010 | 06:18 PM
StiCk3's Avatar
StiCk3
i have a stock soarer ECU on mine, no mods to it. Check to see if the ECU is getting power first before you go buy another ECU
Old Aug 21, 2010 | 06:24 PM
empera's Avatar
empera
i believe me and my buddy checked that last night, im pretty sure i was drunk tho so memory isnt working too well....
want me to send my chaser ecu along with the ct 1j manifold for you to try?
Old Aug 26, 2010 | 11:09 AM
empera's Avatar
empera
anyone else have ideas?
Poopra98
Oct 1, 2015 02:49 PM
DirtySc300
Sep 28, 2015 08:45 AM
trevor10
May 5, 2010 07:01 AM
got-sc?
Feb 15, 2010 09:37 PM
atekt
Apr 23, 2007 10:51 AM
