Stupid Fuel Filter!!! Help
Old Apr 12, 2007 | 04:30 PM
over40driv's Avatar
over40driv
I think the real problem is poor thread fit from the factory. My 14mm line wrench slipped on my line nut as well, just wanted to be sure you knew they were avail. Heres how its going to go. With a good fitting wrench on the filter nut, use your vicegrips and get a 1/4 turn at a time like your life depends on it. Then when you get close to the end gas will begin running down your arm the remainer of the 5 min. of removal. While the gas is still pouring you carefully start that nut straightly into the filter nut and 1/4 turn it until it stops leaking ,careful not to oversqueeze the line nut and ruin it. When your done and life has resumed as normal, get some shop rags and mop up the 2 gallons of gas and wash arm. You might want to do this outside so as not to blowup garage, pref. under carport.
Old Apr 12, 2007 | 08:40 PM
RedPhoenix's Avatar
RedPhoenix
thanks, ill try hold the filter with a wrech too, tommorow
i liked your sense of humor too lol.
Old Apr 12, 2007 | 09:39 PM
vwynn's Avatar
vwynn
http://us.lexusownersclub.com/forums...=14717&hl=fuel
check that out
i used that tut and it helps.
Old Apr 12, 2007 | 11:42 PM
PERRYinLA's Avatar
PERRYinLA
Even with a flare wrench it is easy to round the connector, and I ended up using a vise-grip and a pipe wrench to get it off. There are other threads about this issue and one of them describes to process of cutting the lines and patching in high-pressure rubber lines instead.
Old Apr 13, 2007 | 12:45 AM
KrazeMatik's Avatar
KrazeMatik
by doing this... it should get better mpg?
Old Apr 13, 2007 | 05:24 AM
RedPhoenix's Avatar
RedPhoenix
hoping for somethign lol
Old Apr 13, 2007 | 09:37 AM
vwynn's Avatar
vwynn
maybe you can dremel it to make it look like a nut? and then use a smaller size tool? =]
Old Apr 13, 2007 | 11:59 AM
RedPhoenix's Avatar
RedPhoenix
wow. this day was pretty crazy.
started at 9am finished at 1:30. for a fuel filter.
after about an hour of going crazy on the fitting, it finally budged. but it took another 30 min to actually get it out since it was EXTREMELY rusted and it was not wanting to come out. finally got it out, gas everywhere mind you.
go to put the new one in. the rusted fitting isnt going in. 1-2hrs of trying, twisting tugging etc... i finally came to the conclusion... it was not going in.
i jerry rigged it to stop gushing gas everywhere, went to advance auto, got a 1/4 NPT / 3/8 fitting, 1ft of 5/16 fuel hose, 2 clamps. i took bolt cutters, cut the metal line about 2 inches back, and got the hose on, clamped it etc. stopped leaking, car runs.... AWESOME
but the whole time i kept oiling my arm with wd40 to stop the gas a little.. but god damn it... you lay in gas for hours, you get chemical burns! my whole left arm is twitching, red, burning, and making me miserable.
all for a fuel filter
ill get pics later after i tend my burns lol
Old Apr 13, 2007 | 12:06 PM
sc250tt's Avatar
sc250tt
i was having the same problem with my sc400 .i rounded it up ,tried a visegrip no luck ,monkey wrench no luck .all i did was pour half tank of gas on my driveway but i was thinking you can probably remove it by putting a monkey wrench on the fitting and using a wrench on the filter (other side) of the filter .if not jus buy a new line at lexus
Old Apr 13, 2007 | 12:08 PM
KrazeMatik's Avatar
KrazeMatik
have you guys ever heard of RUST BUSTER? they work pretty good, anyways where do you guys buy your fuel filter at? and how much do they run?
Old Apr 13, 2007 | 12:21 PM
RedPhoenix's Avatar
RedPhoenix
$15 at advance auto
monkey wrench didnt do crap haha.
Old Apr 13, 2007 | 02:49 PM
over40driv's Avatar
over40driv
I bought a Lexus filter because I had thread problems with an aftermarket filter before on an 89 Supra Turbo, forget the price.
Old Apr 13, 2007 | 03:31 PM
lexusondubs's Avatar
lexusondubs
dubsonlexus
matt hopefully that will remedy your hess problem !!
Old Apr 13, 2007 | 03:43 PM
shlounek's Avatar
shlounek
Or for fun sakes, take it to the dealer, tell them i need my fuel filter changed. and through the windows peeep at them swaering profanities trying to get it out. It would be worth the $70.00 lool
FYI. I tired changing mine on the 2nd SC I had, once I saw the steel lines where bending, I was like screw it.
Old Apr 13, 2007 | 07:03 PM
VGnomore's Avatar
VGnomore
Wow I thought I was the only one...Mine started to strip so I screwed it back in.
