brake upgrade.
Old Apr 10, 2007 | 09:51 AM
aaronjz's Avatar
aaronjz
Default brake upgrade.
is anyone in here running the ls400 brakes. im put one on and it didnt grab me that they were that big . i need spacers to fit my +38 offset rims. just wondering for those who using the ls400 brakes what size are your spacers and/ or your rims size/measurements.
Old Apr 10, 2007 | 03:59 PM
Black_SC's Avatar
Black_SC
i have 19x8.5 +24 up front and it barely clears. you would think they were scraping.
Old Apr 10, 2007 | 11:58 PM
aaronjz's Avatar
aaronjz
which spacers are you using? did u pull or roll the fenders at all
Old Apr 11, 2007 | 08:10 AM
Blizzy's Avatar
Blizzy
this is totally dependent on the wheels. My front wheels are +37 offset, but I could fit an ant farm between my calipers and the spokes.
(1) Measure the gap between your stock calipers and your wheels at the point where the gap is narrowest.
(2) Take off the wheel and measure the difference in width between the stock caliper and the LS400 caliper at that point.
(3) Calculate the difference. Then, give yourself a few mm buffer. That is the spacer size that will be required to fit the bigger calipers.
There is no way of telling how big of a spacer you need since each wheel is unique. The only way to know for certain is to take the measurements.
Old Apr 11, 2007 | 05:35 PM
angyll20's Avatar
angyll20
can't you just make sure that you get wheels that will fit the ls400? I know my wheels are suppose to fit the supra TT which is the brake upgrade I plan to do so I don't think I should have any clearance issues. Or you could just buy wheels that are specifically for big brake clearance.
ct200
IS F (2008-2014)
Jun 23, 2014 04:01 PM
JeffsLS400
Nov 23, 2010 12:35 PM
irshad
Mar 30, 2009 03:25 PM
ifilrx
May 4, 2007 08:37 PM
HonDon7
Wheels, Tires & Brakes Forum
Jan 30, 2002 07:21 AM
