Check Engine Light? Help please
Old Mar 15, 2007 | 07:05 PM
eskinol's Avatar
eskinol
Default Check Engine Light? Help please
Hey guys, just 20 mins ago while I was driving my brother to his work, my car threw a CEL. I don't even know where to begin. How would I diagnose this? Any guidance as to how to approach this problem would be greatly appreciated. Thanks again
-esk
Old Mar 15, 2007 | 07:28 PM
SC4-94's Avatar
SC4-94
Default CEL light
Go to an AutoZone or similar parts store and have them read the code for you. Autozone does it for free. Then search whatever codes they read.
Old Mar 15, 2007 | 07:51 PM
sliva001's Avatar
sliva001
Default How to read codes
Switch ign
Open your hood
locate the "diagnosis" box (intake manifold area)
Open the box
Get a wire
Jump TE1 to E1
Go inside the car
read the code (kinda like morse code)
i.e. 21 is
blink.blink....blink.........................(repeat)
if there are 2 codes or more, lower code is displayed first
Old Mar 16, 2007 | 03:19 AM
eskinol's Avatar
eskinol
Thanks, I'll try that out asap.
-esk
Old Mar 16, 2007 | 01:09 PM
eskinol's Avatar
eskinol
Alright, I had time to do it today. I got b.b.b.b.b.b.b...b...... repeat. Would that mean 71 correct?
I did a search and found this thread
https://www.clublexus.com/forums/sho...c300+cel+codes
It says that 71 is just EGR. If thats the case, I feel at ease. I was worried it could of been something worse. At the same time, I notice in the list it has codes for turbochargers? Is that from a Soarer? Or would the codes still be the same? Thanks again, I'm going to go double check it to verify I'm only flashing 1 code, 71.
-esk
Old Mar 17, 2007 | 06:44 AM
sc250tt's Avatar
sc250tt
-esk
all soarers use the same diagnostics sc400,300,and 2.5 tt .you go about the same way diagnosing it. i think my sc300 has the same code .jus been too busy to fix it
Old Mar 17, 2007 | 09:16 AM
BLovesc's Avatar
BLovesc
Hahaha my car has the exact same code. but i have it good enough to have acess to a snap on scanner. so less work but i wonder what the fix is?
Old Mar 17, 2007 | 01:42 PM
eskinol's Avatar
eskinol
Yeah, I wonder what the fix actually is as well. If the fix is something that will allow me to utilize block off plates and somehow trick the sensor that its in proper working order, I'd like to do this. Of course if the problem has something to do with this section of the egr system.
-esk
dadewi
GS - 1st Gen (1993-1997)
12
Oct 22, 2018 12:45 PM
diverchris
Dec 27, 2010 07:43 PM
desol11
May 8, 2008 02:40 PM
SDJZZ31
Jun 17, 2005 01:18 PM
ursrob
Mar 24, 2003 08:24 PM
