drivers side will not unlock
Old Feb 17, 2007 | 08:16 PM
achap's Avatar
achap
Exclamation drivers side will not unlock
Hey guys,
just today I could not unlock the drivers' side door on my 1992 SC400 either with the key or from the inside. It feels like there is something in the way or bent. I think it's probably a problem with the actuator, but I need to unlock it to open the door to replace it.
Any suggestions? Help.
Old Feb 17, 2007 | 08:43 PM
aliga's Avatar
aliga
Former Sponsor
contact technics, he is having the same issue. you may need to break the door panel to get access to it.
sounds like the drive actutator, if you do need one, i have them.
Old Feb 18, 2007 | 07:20 AM
achap's Avatar
achap
I think I will have to break the door panel, half the screw holes are already broken due to age.
Hopefully won't be too difficult to unlock and open it once I can access the insides.
If I need it, how much for the actuator?
Old Feb 18, 2007 | 10:20 PM
visi0n's Avatar
visi0n
if it feels like the door handle on the outside swings with no resistance, your lever has broken.
it did that on my car. i had to cut a huge hole in my mint grey door panel to get the door opened. i eventually have to purchase a new door lock mechanism box.
Old Feb 18, 2007 | 11:03 PM
whiteSc3's Avatar
whiteSc3
Mine jams every once in awhile... It takes some time, but I am always able to wiggle the inside lock, and play with the key in the door until it opens.
Old Feb 19, 2007 | 10:43 AM
semdaddy's Avatar
semdaddy
happend to me once i sprayed some wd40 in there..worked like a charm
Old Feb 19, 2007 | 12:56 PM
aliga's Avatar
aliga
Former Sponsor
Todays special, Driverside Actuator: 80 shipped.
Old Feb 21, 2007 | 08:54 PM
achap's Avatar
achap
Yesterday I was able to get the door open after breaking the inside door panel. Removed the actuator and it had a broken spring. It seemed to be involved in returning the mechanism after the door handle if pulled. Replaced the spring and it works like new again.
Old Feb 22, 2007 | 05:19 AM
icec0ld's Avatar
icec0ld
i'm kinda having the same problem with my sc, except that only the driver side cannot unlock from the outside. it can lock with the key, and lock/unlock from the inside switch.
is it also the lock actuator that's causing it?
Old Feb 23, 2007 | 10:07 AM
argon's Avatar
argon
was having the same problem with my SC just a few days ago was able to access the cables connecting the latch and the lcoking mechanism by removing the window trim and forcing the door panel open a little from the top...broke some clips in the process but nothing major...and pulled on/played with that till it unlocked then i opened up the door, and disconnected the lock cable from the latch (blue tipped if i remember correctly...the other is yellow?) and unplugged the harness that powers the locks so they'll never lock again...but my car doesn't have door handles so her being locked isnt exactly a big deal to me...
the culprit was that somehow the cable was sitting incorrectly and the latch wasnt able to pull on the threaded cable properly...dunno if you have the same problem but thats how i was able to fix mine...
gulleyman
GS - 1st Gen (1993-1997)
15
Sep 19, 2021 08:05 PM
Limen
Aug 28, 2007 05:48 AM
jsmith55
Jun 1, 2007 12:16 AM
LS_4Will
Nov 13, 2004 09:41 PM
One HoT
Jul 11, 2003 10:05 PM
