LED Tail Lights Teaser
Old Feb 4, 2007 | 11:26 PM
Black_SC's Avatar
Black_SC
cant wait for the final product.
Old Feb 5, 2007 | 07:52 AM
Lex*Toy's Avatar
Lex*Toy
Cant wait to see the pics... I have one of my 97 tail lights out for the same retrofit. Except, I chose to work with red superflux leds b/c of their greater light intensity and viewing angle.
Unlike yours, I am working on a low profile board for the upper rear light, as well as the brake application.
Personally, it is way too much work involved for a partial led retrofit.
Maybe I will post-pone any plans now to see what you come up with
Old Feb 5, 2007 | 08:11 AM
mitsuguy's Avatar
mitsuguy
Maintenance Moderator
my question is this - how are you handling running light vs brake light...
in the stock setup, you've got a dual filament bulb, are you running two separate power supplies with different resistors, or just adding more led's to be on with application of the brake?
Old Feb 5, 2007 | 01:14 PM
CleanCL's Avatar
CleanCL
lextoy: i am using red superflux LEDs, like OLT said, heat/time is the main problem, which is also a reason i did not do the running lights because those will have the greatest risk of problems.
mitsuguy: in the the 97+ tails, there are no dual filament bulbs, but i do know a work around for that as well. there is a flasher unit you can buy which dims the LEDs and then brighten thems.
Old Feb 5, 2007 | 01:27 PM
Lex*Toy's Avatar
Lex*Toy
CleanCL,
You are right about you using superflux led. I can barely make out the square outlines.
I am curious as to why you chose to go with RED leds for the turn signal application instead of AMBER leds?
Also how much prep have you done for the tails- in terms of total man-hours? 6 months is a long time to experiment...
Old Feb 5, 2007 | 02:14 PM
CleanCL's Avatar
CleanCL
because i didnt like the yellow turn signal. i'm spraying the amber with a red coat as well.
well i basically wanted to do this right the first time... picked out LEDs, picked out different resistors, soldered a bunch of test boards, ran them high and low to see what it would be like with surges/drops. also had to decide how many LEDs would look appropriate and how to mount the boards. at first i actually started to cut up the housing, but decided to go a totally different route with layout/mounting. as it stands with my current set up, there is no physical modification to the tail light other than opening it up and coating the amber section red. i also decided to use 7440 sockets so they plug right in to the stock wire harness with no tapping/splicing needed.
Old Feb 5, 2007 | 08:33 PM
ThatDoodle's Avatar
ThatDoodle
very cool. Can you post some pics of the tails with the lens on?
Old Feb 5, 2007 | 10:42 PM
SUPRMSC's Avatar
SUPRMSC
offtopic but that sig is inappropriate. IB removal
Old Feb 14, 2007 | 08:52 PM
omarg's Avatar
omarg
i've been dreaming of doing this mod to my ls400 for some time. what is the "final load point"? I just spent the past couple days learning about leds, resitors and soldering. I really want to do this mod. Is it just too difficult?
Old Feb 14, 2007 | 10:27 PM
$C300's Avatar
$C300
sry to stray off topic but i remember 92-94 tails with out the diffusers, they looked real good but i cnat fine the tread.
Old Feb 15, 2007 | 11:23 AM
mikeloc24's Avatar
mikeloc24
Jose, in using wedge bulbs AND LED's in the same tail lamp, will the LED portion of the tail lamp light up a split second prior to the wedge bulb portion when the driver applies the brakes?
Old Feb 15, 2007 | 11:56 AM
ACleanSC4's Avatar
ACleanSC4
I don't think that is Jose...he is CleanSC...this is CleanCL...
*sighs* too many owners with "Clean" in their name now
OG Baby!! lol... [/rant]
Old Feb 15, 2007 | 01:07 PM
RedPhoenix's Avatar
RedPhoenix
where can i get this?
Old Feb 15, 2007 | 05:28 PM
CleanCL's Avatar
CleanCL
http://www.able2products.com/update/11_1005.htm
scroll down to stop / turn / tail
Old Feb 15, 2007 | 05:29 PM
CleanCL's Avatar
CleanCL
Originally Posted by menappi
I bet it could be kinda cool to use electrolumienscent rope isntead of leds, and you can create an outline. Maybe it would look nicer in the newer style tails...
thought about it, but it didn't come out right. trust me, i thought of every kind of method.
