Uneven wheel gap at front end after spring install??
Old Feb 3, 2007 | 02:27 PM
Edog's Avatar
Edog
Unhappy Uneven wheel gap at front end after spring install??
97 SC300 nice condition.
I just installed the Tanabe NF210 lowering springs and the Front Right has a 3/4 inch difference in wheel gap compared to the front left!!?
I took it back to the shop and they SAID they would switch them left to right/the problem is still there after. I don't trust them 1st of all. They were in there and should have noticed if I had a worn rubber stopper or bad shocks but they are clueless like me and offer no solution.
Any ideas to what a solution would be?
The spring seat which sits between the spring and the car looks to be of smaller volume on the lower side. Could a worn spring seat be an issue? Can this piece be cut to match the other lower side?
Help!! It's driving me crazy!!
e
Old Feb 4, 2007 | 09:03 PM
96sc3's Avatar
96sc3
That is just how lower springs work for our sc's. It is slightly lower in the driver side.
Old Feb 4, 2007 | 09:37 PM
vinh's Avatar
vinh
are they brand new springs?
maybe the springs havent settled yet and your fat booty lowers the driver side faster than the passenger. Give them a while and let it all settle
Old Feb 5, 2007 | 04:36 PM
Edog's Avatar
Edog
Exclamation yea, they are new springs....
So this is a common thing, heh? Could it be the spring seats worn on drivers side? I am the 2nd owner and I am not a heavy person. Argh! I want to fix it!
Eric
Old Feb 5, 2007 | 04:53 PM
Ice350's Avatar
Ice350
Now that I have multi-car experience, I can help you out a little.
Every Lexus is higher on the right side than the left.
Always measure both sides before putting on springs.
Lowering the car won't change the right/left difference. Both sides drop equally, meaning the left will be lower than the right.
If you don't believe it, go to the dealer with a measure and check. All the cars will be higher on the right. The only way to make it even is to use coilovers. However, the right front won't align as perfectly as the left if you make them even. The right side may get within spec range but won't be perfect. If the technician is good, they will be close enough to have even tire wear.
I hope this helps you understand. This means that nothing is wrong with your drop. You just didn't know what to expect. If an even drop is super important, get some coilovers....that's what I did for my SC.
Springs were okay for my G35 because the drop is even. However, the alignment isn't perfect. The right is not as perfect as the left. I don't care, the look was more important to me.
Old Feb 5, 2007 | 05:12 PM
Edog's Avatar
Edog
Default The manuel says you can but the bump stops in 1/2..?
Would this adjust ride height at all? Would it be safe to mess with?
Coilovers? Thats like a whole system right? Would cutting the spring a tiny bit hurt it?
Old Feb 5, 2007 | 07:40 PM
np20412's Avatar
np20412
cutting springs is a bad idea, always.
Old Feb 5, 2007 | 09:55 PM
slo86's Avatar
slo86
you get use to the driver side sitting lower than the passenger side after a while. just get a proper alignment and you'll still have even tire wear left to right. cornerbalancing the car might help. ^^the only way to fix this is to get adjustable coilovers.
Old Mar 9, 2007 | 11:37 AM
Slinger's Avatar
Slinger
I just put TEIN SS Coilovers on mine and sure enough, same thing. Higher on the right side.
If that is how it's supposed to be, I'd rather save the tires and live with it
Old Mar 9, 2007 | 02:13 PM
Khaos's Avatar
Khaos
Maybe this thread will help you out:
https://www.clublexus.com/forums/sho...highlight=sway
Old Mar 9, 2007 | 06:06 PM
RjRacing's Avatar
RjRacing
Your car needs to be professionally aligned. There are three measurements that have factory adjustment on a SC3/400 when getting an alignment, Camber, Caster and Toe. The measurment that is out on your car is Caster and is fully adjustable with two cam bolt that are on each of your lower control arms, but it will also affect your camber as well which is why I say take it to a shop w/ a good alignment machine(ex. Hunter DSP6900) and a good tech to have them do it. It sounds like the shop messed around with your lower control arm when trying to install the springs.
Edit; You did not clerify what you ment by gap, I took it as gap from the fender or front bumper to the wheel but as a re-read it I think you may have been talking about hieght gap
Old Mar 13, 2007 | 01:23 PM
sc250tt's Avatar
sc250tt
yup i have the same springs and same issue .i got use to it already
Old Mar 14, 2007 | 09:58 AM
Luke_in_SD's Avatar
Luke_in_SD
+1
Old Mar 19, 2007 | 10:43 PM
The Ikon's Avatar
The Ikon
good info and good luck...
Old Mar 30, 2007 | 06:43 PM
CCC-TT's Avatar
CCC-TT
wow, i just posted a new thread about this because i just bought an sc300 and it does the same thing but it seems extremely exaggerated(three finger gap on passenger side, barely room for one on drivers side). i have 18" privat fahrens on and i thing the drivers side looks really good, i just want the passenger side to come close to lining up
