for the 18x8.5 and 38 offset its 139.99 each from 1010tires.com
that is ridiculous value. the pattern is not very concentric, but I would bet that an SC could pull it off. 18x8.5 +38 is a little conservative, but a pretty god offset for a non-staggered set-up. Again, the value is huge.
You do relize that they will 'twist' different ways on each side. Another words, on the drivers side they will twist forwrad and one the passengere they will twist backwards. Ever since I found this out i'm not a fan of twist rims at all.
I like the color, but remember you might want a staggered setup later, then you might be stuck with extra rims. Hey if you like, I like, do what you do.
