Code 78 Fuel Pump Control?
Old Jan 22, 2007 | 05:14 PM
cino78h's Avatar
cino78h
Default Code 78 Fuel Pump Control?
IS THIS IS THE SAME AS AN FUEL PUMP OR ECU??please help!thank you all!
Old Jul 22, 2011 | 04:54 PM
dannysc400's Avatar
dannysc400
Can't wait to see the response to this code 78. I just got the code today and would like to know where to start. With the ecu or the pump itself. I will check both either way.
Old Jul 24, 2011 | 07:24 AM
jomidan's Avatar
jomidan
The ECU bypass is easier than the pump and it is on your way to get to the pump. Try the bypass first (cut wires in a way that you can reverse the bypass) and if that does not work continue to the removal of the backseat.
I did both of them.
Old Aug 1, 2011 | 04:37 PM
BobbyB's Avatar
BobbyB
Default fuel ecu
Does the fuel ecu a good fix, even if you have a stock car...no modifications...?
Are there any issues if you do this...thanks.
Old Aug 1, 2011 | 06:37 PM
jomidan's Avatar
jomidan
If it is not broken....do not fix it !!! My car is all stock and it was done because it would take 10 tries to get it started and it was holding back the pump even after it was running.
pyr8
Dec 22, 2014 08:26 AM
JPS
Dec 17, 2014 12:35 AM
NSeagle78
Jul 4, 2012 09:03 PM
CHASER4LIF
GS - 1st Gen (1993-1997)
Sep 19, 2011 07:45 AM
dave_id
Oct 24, 2009 01:43 AM
