Body Kit or Good Drop???
Old Jan 21, 2007 | 09:31 PM
Lucky SC's Avatar
Lucky SC
Default Body Kit or Good Drop???
okay guys i have a problem here...
this isn't really an issue for most people but i live in Georgia where it is very hilly and i have to deal with Speed bumps every day i go to school.
i want to know if i should get the either Auto Couture or Vertex kits i was thinking about and probably not drop it but half an inch bc otherwise it'll be too low and scrape or just lower the car 2" or so and get rid of all wheel well gap but probably not have room for a body kit and have to do 97+ conversion instead...
so basically in short, should i prioritize the body kit and see how much i can drop or do the drop first...
if anyone has both a body kit and dropped their SC and succesivly go over speed bumps every day without ever scratching please let me know what solution you found, i would hate to spend all this money and **** it all up on a speed bump.
heres the picture of the car now with its gaps...
heres what the car would look like with all of the gap gone, courtesy of Black_SC, this is the part in question if i would have enough clearance of speed bumps...
any pictures, advice, or personal stories would be helpful in anyway, i just need a game plan before i start throwing money around, thankyou
Old Jan 21, 2007 | 09:53 PM
Hai_Nguyen's Avatar
Hai_Nguyen
My best advice would be to get a 97+ conversion. The OEM material will be much more durable in case you do scrape. If you do get a kit, get airbags.
Old Jan 21, 2007 | 09:55 PM
TheMole's Avatar
TheMole
Well if you get a bodykit you have to drop it. Maybe you should drop it first and see how it goes. Then decide if you want a bodykit which decreases ground clearance.
jimmyXthai's Avatar
jimmyXthai
get coilovers and adjust it
Old Jan 21, 2007 | 10:00 PM
HmoobSC300's Avatar
HmoobSC300
from the pic it looks like your sc has the same stance as mine after the gaps are gone (can't fit my pinky into gaps). I scrape all the time with speedbumps and what not (I'm on 19 inch volks with no bodykit). previous owner screwed me over and never sent the adjustment keys to the coilovers, so i'm pretty much stuck until I can get a set.
Old Jan 21, 2007 | 10:12 PM
hass's Avatar
hass
Yes, what he says
-hass
Old Jan 21, 2007 | 10:33 PM
yelloa3gti's Avatar
yelloa3gti
do both.. and drive carefully.. of your only doing one.. then lower it.. body kit and not lowered is just weird
Old Jan 21, 2007 | 10:37 PM
Lucky SC's Avatar
Lucky SC
so if i install the coilovers at a shop would it be easy to adjust the coilovers by myself? as in under an hour or so?
bc if ur scraping with no body kit then this could be a real problem i dont want my daily and only car to not be able to go over speed bumps...
i think im gonna put on some HKS RS Coilovers, they look like the best option as of now. i guess from there i can see how much room i have to work with right? just want to know with those coilovers will it be easy to move them up and down to see if i can fit a kit afterwards?
even after my senior year is over in may im either going to Alabama, Clemson, or Florida State i haven't decided yet, and for all i kno it could be a speed bump minefield at any of them lol
Old Jan 21, 2007 | 11:13 PM
daSC4's Avatar
daSC4
I have the same body style as you w/Tein SS and I'm dropped to where I have about a 1cm gap between the wheel and fender(probably less). Everytime I go over a speed bump I slow down a lot and i mean A LOT to where I'm going like 1mph. I do this because If i go over the bump too fast like an idiot I might scrape. When I go out of steep driveways sometimes I scrape the bottom part of my front bumper, even if I do angle out. My suggestion to you is do a 97+ body upgrade because it looks so much better than the pre-97 body. Don't slam the car like I did and leave 1.5 finger gap in front and 1 finger gap in the rear.
Good Luck with your decision!
Old Jan 21, 2007 | 11:40 PM
Black_SC's Avatar
Black_SC
lower it first.....wheel gap = horrible.
Old Jan 21, 2007 | 11:57 PM
vince1128's Avatar
vince1128
i personally think the 97+ looks better then the body kits, so i say do that and lower it some and it'd look awesome...
Old Jan 22, 2007 | 12:33 AM
SUPRMSC's Avatar
SUPRMSC
Drop the car, and get an OEM kit.
Dropped + vertex = Death
I repainted my front bumper 4 times so far.
Old Jan 22, 2007 | 08:01 PM
Hil's Avatar
Hil
i say get adjustable coilovers too
Old Jan 22, 2007 | 08:27 PM
Lucky SC's Avatar
Lucky SC
k i think i'll go with the coilovers first then...
has anyone heard any good things about the HKS RS Coilovers?
they retail at like 1900$, i think i could get them at around 1k or so...
i've heard they are a lot better then tein
Old Jan 22, 2007 | 09:25 PM
HmoobSC300's Avatar
HmoobSC300
I have teins. I recommend staying away from them.
