MKIII W58 question
Old Jan 17, 2007 | 09:23 PM
Grey Ghost's Avatar
Grey Ghost
Default MKIII W58 question
I read somewhere that MKIII w58 does not fit int sc300. Is it true?
Old Jan 18, 2007 | 11:31 PM
slo86's Avatar
slo86
w58 from a mkIII uses a different bellhousing, therefore its not a direct swap.
Old Jan 19, 2007 | 10:40 AM
MJHSC400's Avatar
MJHSC400
It will probably work with your SC bell and tail housing--- but you should check on the ratios to see if they may differ, and if so, it could be a favorable difference...
Old Jan 19, 2007 | 02:35 PM
slo86's Avatar
slo86
http://mkiv.com/specifications/ncf/ncf93/ncf124.jpg
"the w58 has the same basic construction and operation as those of the w58 of the previous 7m-ge engin model. However, the operability of its shift control system has been improved by making the shift stroke shorter."
all w58 gear ratios are the same. the differnce is in the bell housing.
earlier SC's (92-94 i believe) still used the same shifter as the mkIII supra.
Old Jan 20, 2007 | 01:10 AM
Grey Ghost's Avatar
Grey Ghost
For 2jzgte swap, which bellhousing is necessary for w58?
Old Jan 20, 2007 | 02:13 AM
garethr's Avatar
garethr
SC300 or Supra Mk4 n/a, but is the W58 strong enough for a 2JZ-GTE?
Old Jan 20, 2007 | 09:28 AM
slo86's Avatar
slo86
this forum does have a SEARCH feature
Old Jan 20, 2007 | 10:21 AM
Grey Ghost's Avatar
Grey Ghost
I have tried search button and couldn't find the answer. Maybe I should have changed the wording. In any case, I posted this thread to find some answer and I appreciate you guys for clear answers. Thanks.
tjfrom215
Dec 21, 2020 11:33 PM
whooper20
Mar 5, 2012 10:02 PM
xspsi6
Aug 10, 2011 12:54 PM
snomanlex
SC400 / 300 Classifieds
Aug 11, 2010 10:40 AM
RedPhoenix
Mar 21, 2008 04:08 PM
