g-stop ss lines
Old Dec 19, 2006 | 08:23 PM
hknubsauce's Avatar
hknubsauce
Default g-stop ss lines
i tried searching, but came up empty. i'm trying to find out if g-stop ss lines for the gs3 will fit the sc3? i plan on doing a supra tt bbk swap.
thanks, jason
Old Dec 20, 2006 | 06:36 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
What would make you think brake lines for the GS would fit the SC????
They are two completely different cars, chassis', & bodies.
Old Dec 20, 2006 | 06:57 AM
np20412's Avatar
np20412
they do share the same engine, so maybe thats why he thought that. It's not THAT far fetched, I mean the LS brake lines are the same as the SC4 lines and those are two different chassis/body sharing the same engine
Old Dec 20, 2006 | 10:39 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Are the LS lines the same as the SC's or do they just happen to "fit"?
Old Dec 20, 2006 | 11:23 AM
np20412's Avatar
np20412
from what I've gathered on this forum, they are the same...
Old Dec 20, 2006 | 11:49 AM
mkorsu's Avatar
mkorsu
Zombie Slayer
Very interesting. I am surprised that they both use the exact same lengths.
SC
Wheelbase 106in
Length 192.5in
LS
Wheelbase 112.2in
Length 196.7in
The extra 6 inches in wheelbase alone leads me to believe that the LS just happens to fit the SC since it's "longer", but that the SC lines wouldn't quite reach on the LS. But, who knows
Old Dec 20, 2006 | 01:15 PM
Sc dRifta's Avatar
Sc dRifta
*****Do not buy from this member until further notice *****
its toyota..... you all use the same oil filters too
Old Dec 20, 2006 | 03:00 PM
mkorsu's Avatar
mkorsu
Zombie Slayer
That makes no sense. We're talking about interchangablity between models/classes not "will a toyota filter fit on my Lexus" newb question.
Old Dec 22, 2006 | 09:52 AM
Boostshakalaka's Avatar
Boostshakalaka
hahahahahhahahaha
i'm thinking about getting the technafits for the sc when i do the ls brake upgrade in january, i'll let u gus know how it ends up
Old Dec 25, 2006 | 01:21 AM
SCoupe's Avatar
SCoupe
CL Folding 25,000
...The extra 6 inches in wheelbase alone leads me to believe ...
imho, I respectfully disagree with that, here's why. The wheel base has absolutely nothing whatsoever to do with the length of the brake hose. The hose just make a flex conection between the brake hard line and the caliper. that distance is going to be very similar among passenger cars.
For reference, the brake hose fittings on the SC are 10mm x 1.0mm. Anything with those fittings will screw on. The lengths of the hose are also probably very close given that the suspension is similar. It more the even odds that the gs3 lines fit.
(Are you suggesting that they should be 6 inches longer??? He's not asking about the hard lines, and yes, they'd likely be longer, he's asking about the hoses.)
Old Dec 25, 2006 | 07:06 PM
ki_soarer's Avatar
ki_soarer
i would just buy the supra ones... they work fine... even with LS calipers.
turtelshea
Suspension and Brakes
May 3, 2018 12:57 PM
6spdGS300
GS - 1st Gen (1993-1997)
Sep 12, 2014 05:59 AM
1.5jzsupra
Feb 16, 2010 12:04 AM
skperformance
18
Jan 9, 2007 10:34 AM
HKGS300
Apr 18, 2004 05:09 PM
