GTE head on GE block
Ok I am new to these cars so please keep that in mind.
I would like to 1.5jz an SC300, as this would take care of the crossover manifold and would allow my to run a coil type ignition. The flaw with this is that I am accustom to AEM EMS and there is not a PnP version for this applicaiton. In doing some research, I have read several places that the ge and gte blocks are identical. Would it be possible to place a 2jZGTE (tt) head on a GE (NA) block , thereby allowing me to use the gte harness and eliminating distributor/ NA manifold and allowing me ot use AEM?
TIA
TIA
TIA
TIA
-scott
So how do you get away with running a 1jz head on a 2jzge block without hte crank angle sensor? when I did a 6bolt swap on my DSM, i used the Cam angle sensor (hall effect style) to simulate the crank angle signal, thereby still being able to use the stock ecu.
What I'm getting at is, I would like to do ditch the distributor in favor of a Coil ignition system and I would like to be able to run a 2jz flavor of AEM. I do not want to buy a USDM 2JZGTE long block. I was thinking of doing a 1jz head with a 2jz bottom (as mentioned on clubna-t.com) and getting a 1jz to 2jzgte harness allowing me to use the TT AEM box.
any suggestions?
any suggestions?
any suggestions?
any suggestions?
So the answer to your question is that it isn't possible to run a 1jz head on a 2jz-ge motor without re-instrumenting the motor with crank/cam sensors that are compatible with your ECU.
-scott
http://www.clubna-t.com/forums/showthread.php?t=120 <-- This thread on clubna-t.com talks about using a ge block wiht a 1jz head.
Scott, you've more than answered my question. Looks like i'll be sticking with my original idea of 1jz.
Your '92 sc300 uses the distributor for cam AND crank position. Putting a GTE head on a GE block will give you a cam trigger off the intake cam but no crank trigger. The TT crank sensor mount is unique to the GTE oil pump; unfortunately, the GE oil pump has no crank sensor mount. Now, you could instrument the crank pulley with a Hall sensor, but then you'd have to use a Universal AEM EMS, or you could buy a Honda EMS (which supports Hall effect) and modify the wiring harness to accomodate the Honda ECU connector.
-scott
-scott
SO the oil pumps are interchangable? In theory you would be able to use a 1jz oil pump (which form what i have read is the same as the 2jzGTE pump) on the 2JZGE block and continue to use the 1JZ head Cam angle sensor?
Soarer 1JZ motors are considerably cheaper than the Aristo 2JZ. Plus the 1JZ is a simple PnP swap. The GE block is readily available and quite cheap... ~$200
