1jz power steering pump
Old Oct 16, 2006 | 06:29 PM
dubstar's Avatar
dubstar
Default 1jz power steering pump
i believe that my power steering pump is going out on my 1jz. makes a little noise. just wanted to know if i would need to find a 1jz PS pump or if any of the other pumps (2jz-te or 2jz-ge) would fix the problem. thanks
Old Oct 18, 2006 | 03:27 AM
philauldridge's Avatar
philauldridge
The ge will most likely not work... with the turbo intake, you'll need the pump with the remote fluid reservoir.
Old Oct 18, 2006 | 06:48 AM
sc250tt's Avatar
sc250tt
the ge will work ,just have to take off the resivior
Old Oct 18, 2006 | 06:50 AM
plex's Avatar
plex
1UZFE/2JZGTE
I was about to say the same thing use the GE and I'm assuming you already have a SC400 or TT MKIV Resevoir.
Old Oct 18, 2006 | 07:24 AM
sc1jzgte's Avatar
sc1jzgte
also make sure that there is fluid in it. If theres a leak in the line which is very common, it will make that noise when it gets low, if you just fill it up it will be fine, then fix the leak obviously.
LexusFTW
SC400 / 300 Classifieds
May 29, 2014 12:30 PM
SupraDremr
Oct 26, 2013 05:00 AM
TTschmitta
Jan 6, 2013 07:21 PM
BSC300TT
Mar 24, 2009 08:22 AM
Ay-nako
Dec 22, 2007 04:10 PM
