Project Nearing Completion, pics
Old Sep 25, 2006 | 11:21 PM
  #31
whiteSc3's Avatar
whiteSc3
Cool car looks good, best of luck with it.. What type of nitrous kit are you running? Where did you mount the bottle etc? Thanks -Brett
Old Sep 26, 2006 | 07:13 AM
  #32
motorheaddown's Avatar
motorheaddown
Originally Posted by JoshFSM
I see the distributor drive gear hole on the exhaust side. Is the plan to use the distributor base for crank and cam signals? Obviously, you're going to a COP ignition.
-scott
Old Sep 26, 2006 | 08:24 AM
  #33
streetracr's Avatar
streetracr
man that car, the paint, the engine set-up is all just SICK!!! wow, i'm really impressed, i am assuming you are doing all the motor work, swap, etc on your own? wouldnt it be easier to have the r154 5 spd tranny than do all the extra work to put in the getrag 6 spd?
is that a stock lexus silver paintjob because it looks awesome!
Old Oct 5, 2006 | 04:55 PM
  #34
chidoks's Avatar
chidoks
he's on the distributor
-scott
Old Oct 16, 2006 | 05:30 PM
  #35
over40driv's Avatar
over40driv
Twin 44s, but I only see 1 turbo.
Old Oct 16, 2006 | 05:46 PM
  #36
Sly Guy Yu's Avatar
Sly Guy Yu
twin 44mm Waste Gates. Those purple things.
Old Oct 19, 2006 | 03:39 PM
  #37
over40driv's Avatar
over40driv
Thank you.
Old Oct 20, 2006 | 12:56 AM
  #38
lsflame's Avatar
lsflame
boy that looks like workaholic's old car! Could it be?
Old Oct 20, 2006 | 07:41 AM
  #39
PM Supra's Avatar
PM Supra
Agreed... OEM GE cams will hold you back at higher boost levels. BL made 720whp at 30psi all boost with custom 264 cam regrinds.
-scott
Add stock intake manifold and throttle body
Old Oct 20, 2006 | 08:10 AM
  #40
ACleanSC4's Avatar
ACleanSC4
Yes it is...
awesome work...looks
Old Feb 19, 2007 | 04:20 PM
  #41
simann's Avatar
simann
Is this an NA-T?
Old Feb 19, 2007 | 05:07 PM
  #42
tsopranoMB's Avatar
tsopranoMB
Originally Posted by simann
Is this an NA-T?
yep..,,,,,.
puff
Performance
62
Nov 13, 2011 10:48 PM
SCORTIZ
Jun 15, 2009 01:57 AM
carchitect
Performance
30
Dec 27, 2007 07:57 PM
ISxSuLLuNg
Performance
96
Feb 28, 2006 09:40 AM
RobSoVIP
Jan 18, 2005 11:44 AM
