95 sc400 trunk pro
Old Aug 18, 2006 | 04:55 PM
evilsc400's Avatar
evilsc400
Default 95 sc400 trunk pro
guys i just got me a 95sc400 and i am having pro with my trunk i can not open it
is there any way i can open the trunk. help me out guys
Old Aug 18, 2006 | 05:22 PM
brand0119's Avatar
brand0119
you cant open it with the key or the button inside?
Old Aug 18, 2006 | 06:05 PM
Kimbroz's Avatar
Kimbroz
if you must......use a crowbar?
you didnt read that from me.
the best part about receiving a car is dicovering new things
EXPLORE.
Old Aug 18, 2006 | 06:10 PM
Sc dRifta's Avatar
Sc dRifta
*****Do not buy from this member until further notice *****
ahaha u got 2 options electrical or mechanical electrical u add a +positive connection to a certain wire and it opens or u remove ur rear seats remove the rear deck remove center subwoofer then get a bunch of extensions and remove the 2 12mm bolts that hold the locking hinge in place i use to work at a salvage yard only way with out destroying the trunk
Old Aug 18, 2006 | 07:44 PM
evilsc400's Avatar
evilsc400
thanx guys i am gona try this
Old Aug 19, 2006 | 12:25 AM
dinhNER's Avatar
dinhNER
too bad you cant access it from the back seats bc its blocked by the gas tank , that always amazes me
Old Aug 19, 2006 | 12:35 PM
FireCode's Avatar
FireCode
make sure it is unlocked first from the inside...stick your key in the thingy below the steering wheel ....I would hate for you to go through a crazy process for an easy fix.
Old Aug 20, 2006 | 11:35 AM
evilsc400's Avatar
evilsc400
i try that but my key dont open that lock from the inside any other way to open it
Old Aug 20, 2006 | 11:36 AM
Sc dRifta's Avatar
Sc dRifta
u remove the center subwoofer from inside the car and if u see the gas tank its just an interior piece held by clips slight pressure will push that pieceout then u can remove the bolts
Old Aug 20, 2006 | 11:37 AM
Sc dRifta's Avatar
Sc dRifta
http://www.directwholesale.net/diagr...8886&MakeID=27
wiring diagram for alarm and trunk release
levinsoy
Jun 5, 2020 07:05 PM
xxc34
16
Mar 28, 2019 07:21 AM
rotor
Mar 5, 2013 10:21 AM
lexusben
Jun 1, 2011 05:43 PM
telesat
Feb 24, 2008 04:40 PM
