rear end squeeks... wtf is it?
Old Aug 7, 2006 | 11:50 AM
svtdubs's Avatar
svtdubs
Default rear end squeeks... wtf is it?
going over small bumps I can hear a squeeking noise what sounded like it was coming from the left rear shock so I replaced all 4 with coilovers and the noise is still there. Im assuming it is the bushings but let me know what you guys think it is, where I can get the parts I need, because I cant take it anymore.
Old Aug 7, 2006 | 11:53 AM
ACleanSC4's Avatar
ACleanSC4
sounds like bushings to me...i solved my squeeking problems with Daizen bushings all around...
Old Aug 7, 2006 | 12:14 PM
howiedoit's Avatar
howiedoit
My 95 used to squeek just like you described. I took it to TM Engineering and Todd said that he saw a pattern with the 95 SC3 autos with this problem. I don't know if yours is a 95 auto, but if it's not, it's still probably the bushings. Daizen bushings will take care of it, like Tony said.
Old Aug 7, 2006 | 12:23 PM
svtdubs's Avatar
svtdubs
yes its an auto 95, what was your problem? the bushings also or something else they found with the 95 autos?
Old Aug 7, 2006 | 01:27 PM
Tammy's Avatar
Tammy
Agreed..
Replace all the rear bushings. The original fronts were installed at the same time, it's worth a look for their replacement also.
Old Aug 7, 2006 | 01:37 PM
howiedoit's Avatar
howiedoit
I believe it was the rear upper control arm bushings that went bad in my car, causing the squeeking over speed bumps and dips, etc.
Old Aug 14, 2006 | 07:33 PM
maikeru's Avatar
maikeru
Check your rear bumper, I had a similar squeek that only happend when I went over bumps. Once I accidently bumped my rear bumper with my knee and it made that same noise. When I check from inside the trunk, there were some bolts loose that held the bumper to the body. I think there are four bolts? they are under the carpet by the corner of the trunk. When I tightend up the bolts the squeek was gone!
Old Aug 16, 2006 | 02:47 PM
rushmore9's Avatar
rushmore9
I have an extra set of Vlamos bushings for the upper rear control arms if you're interested. I'm selling them on behalf of Andrew... so you pay regular price without the shipping from Australia.
luciano
Suspension and Brakes
88
Dec 14, 2015 10:19 AM
djl
Feb 7, 2005 06:14 PM
Buttercup
SC400 / 300 Classifieds
Aug 20, 2004 07:40 PM
BrianW1122
Dec 24, 2003 08:22 AM
