NEED HELP ASAP!!!!! OBD1 to OBD2 error scanner
Old Jun 13, 2006 | 11:47 PM
zzaldyy's Avatar
zzaldyy
Default NEED HELP ASAP!!!!! OBD1 to OBD2 error scanner
Hey guys what's up! My car is a '95 SC300 OBDI and I recently did the full GTE swap to OBDII. My question is, how do I run the error codes? Basically, I know OBD2 cars utilize a scanner but I don't have that port. Will the paper clip method work?
Thanks for the help!
Old Jun 14, 2006 | 02:04 AM
5spdSC300's Avatar
5spdSC300
Whats up Zaldy. Hows the car running? The paper clip method won't work unfortunately. You have to wire in a OBDII port and pick up a reader to pull the codes. The one good thing about OBDII is that it has a good refresh rate and with certain obd readers, it can display any of the engine functions such as timming which is a big plus for tuning. When timing is being pulled you know your knocking. Sorry to ramble on but click on the link below and it will show you how to wiring in an obdii port with a link to where you can buy the port.
http://www.supraforums.com/forum/sho...d.php?t=283063
~Kevin
Old Jun 14, 2006 | 08:25 PM
JspecSC3's Avatar
JspecSC3
Are you by any chance Vinze's friend with the Supra?
Old Jun 14, 2006 | 08:40 PM
zzaldyy's Avatar
zzaldyy
yep, how do you know vince?
Old Jun 14, 2006 | 08:48 PM
zzaldyy's Avatar
zzaldyy
~Kevin
Thanks for helping me out through my project Kevin! I appreciate it! I just ordered a female obd2 connector. Hopefully this will square things out. thanks again Kevin.
Old Jun 14, 2006 | 09:09 PM
JspecSC3's Avatar
JspecSC3
Through David with the Supra. I was just at your house last night. Thanks for the alternator and fan clutch.
Old Jun 14, 2006 | 10:26 PM
zzaldyy's Avatar
zzaldyy
no prob man. Speaking of David, damn! his car sounds hella feirceee! and the size of that turbo..****ing nuts!
Old Jun 15, 2006 | 02:55 PM
5spdSC300's Avatar
5spdSC300
No problem Zaldy. Glad to help a fellow GTE SC. Keep me updated with your progress.
Old Jun 15, 2006 | 08:05 PM
JspecSC3's Avatar
JspecSC3
Ohh yeah! Just wait til he gives you a ride in it.
Mr.Gs_GTE
May 7, 2016 10:14 PM
ChrisLex87
Sep 14, 2015 01:45 PM
Carfreak70
Oct 13, 2008 09:40 AM
novak82
Maintenance
Jan 9, 2008 08:45 PM
