View Poll Results: ebay rotors?
yes
55
49.55%
no
56
50.45%
Voters: 111. You may not vote on this poll
ebay rotors? yes or no?
Old Jun 7, 2006 | 11:23 AM
LazyAlex's Avatar
LazyAlex
Default ebay rotors? yes or no?
welll..my rotors are all rusted and stuff..so im planin to just buy some drill slots/cross drilled ones..but...should i get them from ebay? or should i just get the "power slot" brand?
http://cgi.ebay.com/ebaymotors/LEXUS...spagenameZWD1V
http://cgi.ebay.com/ebaymotors/LEXUS...WDVWQQtcZphoto
wht u guys think?
Old Jun 7, 2006 | 11:30 AM
ACleanSC4's Avatar
ACleanSC4
lookup 'iRotors' on eBay, i've used all their stuff on my cars for the last 6 years...numerous others on here have their rotors as well...
good luck!
Old Jun 7, 2006 | 11:37 AM
Mwmorph's Avatar
Mwmorph
no.
Crossdrilled are for racing only. They actually increase your stoping distance due to the surface area lost to those stupid holes. The only reason to go crossdrilled is if you race Laguna Seca all day and need the fade resistance. To racers consistency when stopping from 120 to 50 every 15 seconds is more important that single time stopping once in a while.
Slotted is okay, but it dosent make really al lthat much of a difference. Also, going "performance" or "sport" pads/rotors wil make the car jerkier to brake and it will make it harder to brake smoothly which can get annoying. Also, you should never need this upgrade on the street.
Brembo blanks and OE replacements will allow you to brake smoothest and give you a high level of comfort. Brembo blanks and performance pads for best stopping distance but not smooth stopping.
Slotted if you live in mounatainous areas and you need better fade resistance, for normal drivers in surburbia or the city, this is also a bad choice because it decreases your surface area somewhat and increases stopping distances.
Drilled if you are racing all day.
Slotted and drilled is 100% worthless. You increase braking distance even more since you lose even more surface area and you'll never need all that fade resistance. Slotted and Drilled is petty much 100% appearance.
Old Jun 7, 2006 | 01:26 PM
LazyAlex's Avatar
LazyAlex
Originally Posted by Mwmorph
no.
lol..i guess i should just get OEM ones..
Old Jun 7, 2006 | 01:28 PM
sonyman's Avatar
sonyman
Go OEM. What's the price difference anyway? It isn't like you're swapping rotors out that often so why sacrifice anything? Stick with what was designed and tested for your car.
Scott
Old Jun 7, 2006 | 01:37 PM
fjurado1's Avatar
fjurado1
Every car I have have ever owned. I have always had drilled or vented rotors. Those rotors make your pads last longer. Just do a search on brake gassing. That is when you have non-drilled rotors and during braking it creates a gas between the pad and the rotor. Send me and email and I will give you a phone number of a shop I use for performance rotors.
Frank
Old Jun 7, 2006 | 01:56 PM
LazyAlex's Avatar
LazyAlex
honestly..i really just liked the way they looked..-_-
Old Jun 7, 2006 | 02:48 PM
Mwmorph's Avatar
Mwmorph
dont worry about it then, If you really like the looks buy it. It wont drastically increase stopping distances but it might take maybe 10-15 feet more to stop from 60. If you really want it, go for it I'm just being sort of the devil's advocate,
But then lets look at this logically, how many people will look at your brake rotors in a parking lot or while you drive by or pull up next to them? And then there si the price consideration, Brembo blanks and OEM pads will cost much less and give smoother ride with similar stopping distances to crossdrilled/slotted rotors and performance pads which will grab and jolt you forward somewhat and make you look bad at driving when someone else in in the car with you that may not necessarily appreciate the brake "upgrade"(like your signifigant other, family member,etc)
"I dont see how drilled is really going to decrease your surface area that much being the drilled holes are NOT bigger then a brake pad, so no matter what your pad is always touching part of the rotor. but by the hole being smaller then the pad allows this brake gas to be released, in return extendeding the life of the pad.....thats just how i logicaly see it"
braking is a function of Surface area * Force *Coefficent of friction which creates the Force of Friction. Granted the pads are always touching some parts but the less surface area, the lessForce of friction it creates.
For example if you have 1200psi(force)/.35cf(coefficent friction) on both setups, but all other things being equal 15square inches is going to allow a much larger Ffr(force of friction) than 12 square inches.
1 200 * 15 * .35 = 6 300
1 200 * 12 * .35 = 5 040
Old Jun 7, 2006 | 04:20 PM
LazyAlex's Avatar
LazyAlex
makes me want to go oem or brembo blanks..i gota research the brembo blanks..i never heard of thopes before
Old Jun 7, 2006 | 04:23 PM
Mwmorph's Avatar
Mwmorph
http://www.tirerack.com/brakes/brake...tor&group=null
They're called brembo blanks by fans but offically they're just brembo oem replacement rotors. They're really nice rotors and cheap too.
http://www.tirerack.com/brakes/brake...ar=&perfCode=P
http://www.tirerack.com/brakes/brake...ar=&perfCode=S
~240 for 4 rotors(well cheap compared to the other name brand performance rotors), $62 for pads. Best of all you are getting a Brembo product which imho is good quality, instead of noname rotors and pads.
The Satisfied pads are pretty good for OEM replacement. I use them down at the shop all the time and they are pretty nice, not too much dust and performs as expected.
Old Jun 7, 2006 | 05:53 PM
ACleanSC4's Avatar
ACleanSC4
Originally Posted by Memphisacc
Your running these on your stock sc calipers correct ? Hows the wear and tear break dust and so on with these ? Ive just looked them up on ebay...$429 you think they are really worth it ?
I used them with Supra TT front & rear calipers...
You can have them ordered in either drilled, slotted, or both for looks...
If you're going to buy on eBay, check their feedback to separate the true businesses from flakey sellers
Old Jun 8, 2006 | 12:30 AM
LazyAlex's Avatar
LazyAlex
the sc400 and sc300 have the same rotor size?
Old Jun 8, 2006 | 02:46 AM
Mwmorph's Avatar
Mwmorph
what year SC300?
Old Jun 8, 2006 | 09:54 AM
PsiQo1's Avatar
PsiQo1
yeah!!!!!!! thats whats up! me to0 bra
Old Jun 8, 2006 | 04:36 PM
LazyAlex's Avatar
LazyAlex
what year SC300?
1992..is wht i got
