Supra TT Brakes
I know this has been done but I can't find complet info for what I want...
I have 17" Wheels from a GS400 Sport on my 93 SC400. I want to add the Supra TT brakes...what do I need?
Here is what I think but am not sure...
Do I need to do just fron or can I do front and rear?
I know I need spacers(recomondations and where?)
front calipers and rotors? Entire hub? Just the calipers?
Same question for rear.
I want to know exactly I need to get to convert my brakes...
All the upgrades for spped are great...but you have to do the brakes first!
Joe
Joe
I have a SC300 with the GS wheels and the SupraTT front brakes.
Get 15mm spacers made by H&R Springs. I got mine from optauto.com for about $200 for all four. Get the rears so the car will track properly. New studs are included in the kit.
That's all you need. Bolt it on.
If you like or think you need big stopping power then you should definatley go for it. The SC is a very heavy car and these TT brakes have raised my driving confidence tremendously.
I'm still trying to find out about the rear. Anyone have this info?
I still need to know...
When you upgrade to Supra TT Brakes...do you just replace the caliper and use stock SC rotor? Do you replace caliper and rotor?
Do you use stock Supra TT Pads?
Thanks
Joe
Thanks
Joe
Replace the caliper and rotor. The TT caliper will not fit with the Stock SC rotor. The TT rotor is much larger.
I used the stock TT brake pads. I believe they're a high quality semi metalic. A little dusty though. Get the Hawk HP Plus or Blue if you're doing alot of track time.
Heres a link to the thread about SupraTT brakes through Steve at Carson Toyota. I just had them installed on my GS...Steve gives exceptional prices to CL members and is VERY reliable...
-SupraTT front calipers
-Cross-drilled CAD plated front rotors(or stock SupraTT rotors if you prefer to spend less $$$)
-SS brake lines
-Stock SupraTT front pads(he also has other pads if you have a preference)
In case anyone is concerned, the CAD plating literally comes off after 20 miles of city driving.....
https://www.clublexus.com/forums/sho...threadid=17962
-SS brake lines
