Need advice with clunking noise
Old Feb 8, 2006 | 05:42 PM
no2faber's Avatar
no2faber
Default Need advice with clunking noise
Hi,
I'm sure most of you reading the title of the thread are thinking, "he needs new bushings." Well that's what I thought. I got my front LCA's switched out last winter for new supra ones, and I thought the problem was over. Now, with the winter settling in again, I'm hearing the same old clunking noise when I go over bumps.
I have the tokico illumina set for my suspension. Its less than a year old so I doubt it's the suspension. Plus, I've heard this sound before with the old suspension. I'm bringing it to a shop to get my trans checked in the next few days so I'll probably ask about the noise too, but just curious if any one have ideas?
Old Feb 12, 2006 | 10:52 PM
UpInTheLex's Avatar
UpInTheLex
upper control arm bushings.
Old Feb 13, 2006 | 09:39 AM
AME_VIP's Avatar
AME_VIP
Cheapest step would be to get it back on the hoist and torque every bolt on the front end to spec.
After doing new Supra front LCA's, some clunking came back. Turned out a front left caliper bolt had worked its way loose a little on my car.
Old Feb 13, 2006 | 11:34 AM
mikeloc24's Avatar
mikeloc24
I've got that damn clunking too...mine is most apparent when I go at slow speeds and brake. As in stopping and backing up out of a driveway. Kloonk kloonk! damn I hate it...like I said, it shows up at really slow speeds and usually when applying the brakes. I torqued the hell out of all the bolts down there. (lca bolts, caliper bolts, etc) and yet the noise is still there. I have the Daizen lower control bushings so I'm assumming it's the upper control arms (I hope not) or the ball joints...
LudeNsoL
May 3, 2013 08:03 PM
808is3
CL of Hawaii
21
Nov 14, 2012 03:41 PM
Mike552
May 23, 2012 04:23 AM
djrazr
May 12, 2010 10:04 PM
jdeanda909
Oct 26, 2009 11:10 PM
