Door won't open - From Inside or Outside
Old Dec 5, 2018 | 01:55 PM
  #31
Clipz808's Avatar
Clipz808
Originally Posted by 04LS671
thanks for the quick reply. I was able to roll the window down, force the unlock from the inside and open the door from the outside. My child safety was on. Now time to remove the actuator and see what’s going on.
Awesome!! I hope everything works out for you.
Old Mar 28, 2020 | 07:37 AM
  #32
JustaGE's Avatar
JustaGE
10th Gear
Originally Posted by stevechumo
The problem might not be the actuator, try this out first. It's also very common for your lock symptom. The little white plastic piece that hold the cable inside the door panel might have been half-way broken. Therefore, it locks up sometimes when you open the door electronically and someones opens it manually at the same time. That white plastic piece costs around $10 at Lexus dealer. It's located at the end of the opening cable near the metal piece near the lock. If you open the door panel, you'll see 2 cables to open the door. Follow the cables to the end and you'll see it. It's hard to explain, but if you go to the Lexus dealer, they'll know. I believe the part number is 90467-07120. With the door swing open, you can take off the door panel easily to replace this piece.
It happened to me and I had to pry up the top door panel from the inside (right above the wooden piece), and pull the lock cable manually to open the door. It's not that hard, but it takes patience. If you try this, be careful not to break the door panel.
how exactly do you pry the panel to access the cables? and where did you pull?
Old May 4, 2020 | 10:28 AM
  #33
Akrums123's Avatar
Akrums123
Originally Posted by Carbon J
I had the same problem with the door handle on the outside not working. Broken small plastic piece that links the handle with the lock assembly. Worked for several weeks, but then the lock aas. went bad. Bought one from Coliseum Lexus and got a discount for being a ClubLexus member. Regular price around $300, got it for $250 also save some money and put it in yourself. Lexus wants around $300 to install this, took me about 2hrs only because I had to drill out a screw.
can you tell me what the name of that part looks like and what it looks like. My Lexus is250 has a problem where I can’t open the door from the outside. I’ve been trying to find the part but I think you found it. Was it easy to install?
Old May 31, 2020 | 06:46 AM
  #34
Oceans13's Avatar
Oceans13
Changed the motors in my lock actuators a few months ago. They all worked but the rear passanger one was louder than the rest. This morning i noticed a double pulse. I tried to open the rear right door, it wouldn't. It tried to manually unlock it from inside, wouldn't. No idea how to proceed.
Old May 31, 2020 | 09:17 AM
  #35
t2d2's Avatar
t2d2
Wrong section ... SCs only have two doors.
Old Apr 12, 2022 | 09:06 PM
  #36
Kolohe2022's Avatar
Kolohe2022
I was able to use a Slim Jim, and about 1 hour of effort to open the door. You have to keep poking around until you find the release, and slowly push on it. If you try and do it fast, it will bend the slim jim and won't open the door.
Old Jul 27, 2024 | 02:01 PM
  #37
mng614's Avatar
mng614
1st Gear
I know this thread is really old but my 2006 is250 front passenger dor won't open. I got the door panel off(I destroyed it) and found the lever I push it and nothing happens
greg3852
Nov 30, 2019 08:04 AM
mkjeffries
Jan 15, 2013 06:08 PM
lexuseng
Jan 2, 2009 12:17 AM
Lexus400mn
Jul 7, 2007 08:17 AM
LS_4Will
Nov 13, 2004 09:41 PM
