what LSD fits SC300 5spd?
Old Jan 1, 2006 | 09:14 PM
FCDRIFT's Avatar
FCDRIFT
Default what LSD fits SC300 5spd?
im looking for a LSD for my 93 SC300 5spd. my big question is, will the surpa ones fit? meaning will the whole rear differential bolt up to the SC mounting points and the SC 1/2 shafts?
also, has anyone gotten any aftermarket LSD (kaaz, trd, etc)? feedback?
Old Jan 3, 2006 | 02:26 PM
SPORTcoupe's Avatar
SPORTcoupe
The whole pumpkin from the Automatic TT Supra will bolt right up. I think you have to replace 1 of the 1/2 axles.
What I did was cheaper, and to me...easier. You take just the carrier out of an auto TT pumpkin, and have a local differential shop swap it into your pumpkin. The reason to get just the carrier instead of the whole pumpkin?
1) Shipping weight(and therefore cost) is just a fraction of a full pumpkin.
2) TT owners who upgrade to TRD usually have the carrier laying around somewhere and will let it got for <$200
3) You get to keep your 4.27 gear which is better for acceleration.
As for other products, I’m not sure, but DaveH is currently working on a LSD. PM me for a link to the place to look for updates.
Cheers,
~Alan
Old Jan 3, 2006 | 03:29 PM
soardrft's Avatar
soardrft
kaaz 2-way is very loud on a cold day, but you can feel a BIG difference when conering. i had cusco as well(just installed wrong) same thing pretty much. if you can put up with a little kicking and the grinding noise 2-way lsd is the way to go. and yes you would purchase the supra lsd when ordering an aftermarket.
Old Jan 4, 2006 | 08:04 AM
SoarerJzz3's Avatar
SoarerJzz3
The na Supra lsd also works but are hard to find. I'll be using a TRD unit.
Old Jan 7, 2006 | 01:46 AM
FCDRIFT's Avatar
FCDRIFT
thanks for the tips guys, im pretty familiar with kaaz and i dont think thats what i want in a daily driver. the stock supra ones are torsen? swapping out just the internals sound good.
Old Jan 7, 2006 | 08:58 AM
96sc3's Avatar
96sc3
does the 6spd gears fit too?
Old Jan 8, 2006 | 07:54 PM
turbo6's Avatar
turbo6
The 6 speed rear does not fit: the internals will not swap (they are larger), and to use the housing you will need a different axle and slightly shorter driveshaft.
The supra NA and turbo automatics will swap, but you need to change out the front flange that attaches to the driveshaft as the turbo rear 3 bolts sit slightly farther apart.
Also from my experience, 98+ needs to swap axles as they are smaller and do not bolt up.
Old Jan 8, 2006 | 09:34 PM
1jzjzz31's Avatar
1jzjzz31
got a kaaz in mine...
works GREAT...
SCVito
May 6, 2022 06:13 PM
XxPainxX
Sep 2, 2011 10:48 PM
2JZGTE SC
Jan 29, 2008 06:47 PM
tuninghaus
Aug 12, 2007 10:10 AM
jgdynamics
Dec 16, 2006 11:35 PM
