Can someone please tell me how to remove the factory fog lights from my 95 SC300? Please? I bought some yellow bulbs to go in there, but I cant get the light out. I see one screw inside the little vent. I've been turning that with a screw driver, but nothing happens! How do I get it out? Thanks!
the factory for lights have 3 screws holding them in...either 10 or 12 mm ..i forget....2 of the bolts are in the rear of the light and one is on the top side of the light..they were easy to get to when i removed my headlights..you can also attack them from underneath but its not as simple..Jeff
oh wow,
it takes that much to take out the fogs? are the headlights easy to remove? Thanks a lot for your response!
you can get to the foglights from underneath the car but you have to remove the lower motor cover.....
to remove the headlight you have to remove the inner fender from the wheel well...take out 2 10mm bolts from the fender and then 1 bolt under the hood by the radiator...then its a job to wiggle the headlight out with out damaging the bumper or fender Jeff
