SC- 1st Gen (1992-2000)
How to remove fog light on the SC300?
Old 09-27-05, 06:53 AM
ifilrx
ifilrx's Avatar
Default How to remove fog light on the SC300?
Did a search..couldn't find nothing on the SC. Wanting to change to a whiter bulb. Thanks.
Old 09-27-05, 07:24 AM
Skulinex
Skulinex's Avatar
if all you want to do is replace the bulb, go from underneath... Take off the screws for the corner of the plastic "undercover" <dont quote me but I believe is about 6 or so of them> and you will have enough space to work but let me tell ya it's not an easy job to hook the H3 holder back <specially if you have big hands>... this is if you are talking for the 95-96 model.. I believe the 97-00 still uses H3 but dunno if it's easier to remove the housing.. this is all out of my head someone correct me if I missed something..
Old 09-27-05, 09:15 AM
ifilrx
ifilrx's Avatar
ok, i just figured it out...after painfully taking out all the of the under cover bolts only to find out that isn't necessary. all you need to do is remove the TWO 8mm screws and ONE 8mm nut from the fog light housing through the front brake duct. DO NOT remove the underbody panel screws...it is not necessary. You have to use your hand to feel where the scews and nut are located on the housing...it's not that hard but takes some time...by the way...i'm not too happy about the "white xenon" H3 that I've got..it still has some yellow tint to it...and they're not as bright as the OEM fog.
Old 09-27-05, 10:10 AM
Skulinex
Skulinex's Avatar
I have always said H3s light output isnt all that great no matter what type you get, once the current ones go bye bye, Ill say hello to HID
Old 09-27-05, 11:10 AM
jdmtruong
jdmtruong's Avatar
Default wat about 92-94?
hmm wat about getting the front corner lens OFF the 92-94 sc? mine is blown and i wanna replace the bulbs. how do i get this out? same way as the 95+? i heard u turn your wheel another way, then unscrew all the wheel well. help?
Old 09-27-05, 11:55 AM
adidosc
adidosc's Avatar
unfortunately man, you gotta go in from underneath. it's a pain i know, but we don't have mch choice. you need to remove a bunch of screws under the cornering light in front of the wheel then stick your hand up and twist the bulb holder out. then you can take it out and swap it with a new one. it's annoying, time consuming (for the job) and even a little dirty... but it is really really easy to do.
hlthlnk
03-05-23 01:07 PM
wrivera283
07-29-13 01:57 PM
truongsean
07-21-10 03:55 PM
08ES350
ES - 5th Gen (2007-2012)
06-25-09 01:58 AM
enterconne
10-31-05 11:56 AM
Quick Reply: How to remove fog light on the SC300?
