Driver side leaning
Old Sep 4, 2005 | 11:45 PM
jacques's Avatar
jacques
Default Driver side leaning
I just install new shocks, springs and LCA's but the driver side of the car is still about a half in lower than the passenger. What could this be? Do I need upper control arm bushings too or is this just normal for the car?
Old Sep 5, 2005 | 02:23 AM
RaynArt's Avatar
RaynArt
could be the springs. seems a lot of eibach people lean to one side, myself included
Old Sep 10, 2005 | 11:16 PM
Jimbo2828's Avatar
Jimbo2828
blaznsc4 before he had teins he brought some shackles that compress a few coils of his eibach spring and it made the car a even drop. it was only like 10 bucks for them
Old Sep 11, 2005 | 12:15 AM
advan7's Avatar
advan7
I've got the espelir/tokico blues and my drivers side is lower too.
Old Sep 11, 2005 | 07:01 AM
wayne's Avatar
wayne
Seems to be a common problem with the SC's. I have the same problem. When I changed my shocks, I even moved the passenger springs to the drivers side and the drivers side to the passanger side and it still did the same thing. I guess i'm going to have to get a set of coilovers eventually.
Old Sep 11, 2005 | 08:50 AM
blaznsc4's Avatar
blaznsc4
yes this is true. my first suspension setup was tokico blues with eibach springs and it sags on the whole driver side. so i went to pep boys and bought a set of shackles which came in four (two shackles for each spring). after install it still sag a lil but not very noticable.
Old Oct 3, 2005 | 07:06 PM
pilip99's Avatar
pilip99
how hard is it to install these shackles? my driver side is really leaning its insane, i have to get this thing even on both sides...
Old Oct 3, 2005 | 11:20 PM
roo's Avatar
roo
those shacles are only a band-aid....they don't fix the problem and make your car ride worse.
someone on here posted a thread about their swar bar being in the wrong position and causing the leaning....
Old Oct 4, 2005 | 09:50 AM
pilip99's Avatar
pilip99
so pretty much the eibachs will just sit this way?? i know this sounds ricy, but can i cut the springs on the passenger side to lower it somemore?? or just save up and get the full suspension like tein,etc...
Old Oct 4, 2005 | 11:18 AM
jacques's Avatar
jacques
I don't think its the eibachs, it has to be something else in the car. Stock springs have the same rate on both sides and don't always sag but even before I put in my eibachs the car started to sag a little on the drivers side, the eibachs just made this more noticible. Others have to adjust their coilovers to compensate for it. It could be the sway bar connection like someone mentioned but it doesn't make much sense since my sways haven't been touched since out of factory. It might some other suspension component that bends over time due to driver weight. It would be nice if we could figure out the real cause of it.
Old Oct 4, 2005 | 11:38 AM
pilip99's Avatar
pilip99
Originally Posted by jacques
I don't think its the eibachs, it has to be something else in the car. Stock springs have the same rate on both sides and don't always sag. Even before I put in my eibachs the car sagged a little on the drivers side, the eibachs just made this more noticible. Others have to adjust their coilovers to compensate for it. It could be the sway bar connection like someone mentioned but it doesn't make much sense since my sways haven't been touched since out of factory. It might some other suspension component that bends over time due to driver weight. It would be nice if we could figure out the real cause of it.
yeah i would like to know the real cause as well since my sway bars havent been touched, and now i have no finger gap on the wheel wells on drivers and like 3 finger gap in the passenger side, way too off for me
Old Oct 5, 2005 | 12:42 AM
STRONG SC's Avatar
STRONG SC
I'm' not sure either. Could it be the cars weight difference? The driver side seems to be heavier w/ the heavy *** driver seat!
Old Oct 5, 2005 | 05:53 AM
Lvangundy
Guest
Posts: n/a
Could this be the recently pointed out sway bar upside-down / up issue?
I don't know where the thread is, but the sway bar end link was up on one side..something like that.
Old Oct 5, 2005 | 07:19 AM
howiedoit's Avatar
howiedoit
i suspect that the sway bar end-link problem isn't the issue in most people's leaning problems, but it's a possibility. please take a look at the entire thread because the proper position of the end-links is addressed towards the end.
here's the link. https://www.clublexus.com/forums/sho...d.php?t=177329
RayOnBoost
Apr 27, 2011 03:15 PM
SOLID300
Mar 10, 2011 09:34 AM
LEXLEE
Suspension and Brakes
12
Apr 27, 2008 11:41 AM
sincityIS
Jun 4, 2007 03:54 PM
genius1512
Dec 12, 2001 05:16 AM
